2010 2011 BMW 5 Series Forum F10 Any issues with installing 343M wheels on 535xi? |
08-25-2020, 11:15 AM | #1 |
Rep 16
Hey guys, does anyone know if installing oem F10 343M wheels on an F10 M sport 535xi model would cause any issues with the transfer case, differential etc?
I would like to install them but wouldn't want to have any issues with the drive/handling. |
08-25-2020, 02:50 PM | #2 |
Rep 5,357
As long as the rolling distance (diameter) of the wheels is the same front to rear you should be fine; square or staggered. Search around as this has been discussed and there is an allowable percentage difference; I just don't remember what it is.
MachF100.00 |
08-25-2020, 02:50 PM | #3 |
Rep 2,590
Tire sizing matters more than the size of the wheel for the 1% transfer case tolerance. I have fit the M5 wheels on my 535xi just fine, 255/35/20 F and 295/30/20 R. No rubbing issues.
2015 BMW 535xi
MachF100.00 |
08-25-2020, 03:04 PM | #4 |
Rep 16
thanks for your input, I read that the rolling diameter cannot exceed 1 percent. I checked this staggered set up of F:245/35/20 and R:285/30/20 and seems to be less than 1 percent so hopefully it should be fine?
08-25-2020, 03:10 PM | #5 |
Rep 16
Thanks, how long have you had them on for? I was thinking of this set up that is less than 1 percent of the rolling diameter: F:245/35/20 R:285/30/20
08-25-2020, 05:41 PM | #8 |
Rep 16
08-25-2020, 05:45 PM | #9 |
Rep 254
08-25-2020, 05:58 PM | #10 | |
Rep 2,590
Rolling diameter is 1.1% different, that's a risky play esp with the rears being shorter than the fronts. Rears generally wear quicker, so that 1.1% will soon grow to more than that amount.
2015 BMW 535xi
Javi51.50 |
08-26-2020, 08:27 AM | #11 |
Rep 73
I’ve been thinking about changing the fronts to 245’s but as you mentioned above, it may be a little stretched out for my taste. 295 is way too much tire
As far as the rolling diameter, I keep an eye on tread wear in the rear. I run them 2 PSI over recommended. But even with slight wear how much is the rolling diameter changing? May be to 1.5%. Overall anything under 2% should be handled by the transfer case since bmw made xdrives with staggered set up...albeit not as agreesive of course |
08-26-2020, 10:31 AM | #12 | |
Rep 2,590
2015 BMW 535xi
08-27-2020, 12:04 PM | #14 |
Rep 16
Thank you all for the valuable info/feedback. I'm new to this forum but love the interaction, knowledge and the experience everyone brings to the forum.
I decided to go with 245/35/20 for the front and 285/30/20 for the rear. After further research and calculations, these sizes should keep me under the 1 percent rolling diameter allowance. I'm thinking of Michelin Sport tires, just undecided if i go with Summer or All Season? Living up north, all season would be a safer bet. Once i figure out how to upload pics, i will share. |
08-28-2020, 02:28 PM | #15 | |
Rep 110
The handle is better (maybe it's just me) but I'll probably need to drop it a bit since the front has some wheel gap. |
08-28-2020, 02:29 PM | #16 | |
Rep 110
08-28-2020, 02:44 PM | #17 | ||
Rep 16
Thanks so much, car looks sick! I also have a 2014 m sport xi, exited to throw them on Wednesday. Your front looks good, I wouldn't drop it but then again dropping the car a tad does make it look more aggressive...I don't think I will though, living in NYC the potholes are ruthless. I wanted to go with A/S tires but they didn't have them in stock so I went with the pilot summer. I will probably throw my stock 19's back on for the winter anyway. |
08-28-2020, 02:46 PM | #18 | |||
Rep 110
Also, NYC kicks my ass with those potholes...stay safe and good luck with your install. |
08-29-2020, 09:21 PM | #19 | ||
Rep 2,590
The main reason I have PS4S's on mine is I had a ton of life left in my AS3+'s on my stock 18's, so I decided to just run them as a dedicated winter wheel setup because why not. Here's mine freshly dropped on Silvers Neomaxx's
2015 BMW 535xi
08-29-2020, 09:30 PM | #20 | |||
Rep 110
I got the AS3s for cheap so I may run them and then go for the as4s. Thanks for the heads up on those. I'll look into them. |
09-06-2020, 08:44 AM | #21 |
Rep 16
I was able to put them, here are some pics. Will look into dropping my car next.
Only issue I have is when going over 60mph and I hit the brakes, my steering wheel begins to shake? Not sure what It may be, I replaced my rear rotors and all brakes about a year ago so I don't think it could be that, possibly my front rotors? Did anyone experience the same after putting them on? |
09-07-2020, 09:48 AM | #22 | ||
Rep 16
