2010 2011 BMW 5 Series Forum F10 Godspeed lowering springs |
09-07-2020, 07:20 AM | #1 |
Rep 92
anyone have these installed? pictures after it settled? dropping these on. 2016 f10 drive. can't wait just ordered it
https://www.drivenbystyle.com/2011-2...ngs-40644.html |
09-07-2020, 04:27 PM | #2 |
Rep 915
I seen a post somewhere about godspeed springs they said they were good. Have to do some searching he dailys them.
here is one on a 550 only shows front wheel. https://www.bimmerpost.com/forums/sh...php?p=26591777
Instgram @burninja
09-08-2020, 09:52 AM | #3 |
Rep 538
I"m curious about these as well. You can buy them direct from Godspeed on Amazon for the same price as OP's link:
https://www.amazon.com/dp/B01N7QYOEF...v_ov_lig_dp_it
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
09-11-2020, 11:47 PM | #4 | |
Rep 92
09-12-2020, 12:50 AM | #5 |
Rep 81
Ssa 22g, also curious about these. Have asked two other people who have them and have heard good things. You'll have to update us on how it goes. I've had second thoughts because I heard it can make your shocks go out quicker but coilovers are also much more expensive so I'm still sitting on it
09-14-2020, 09:45 AM | #6 | |
Rep 538
If you go for them, definitely provide some feed back. This is a mod for me down the road.
09-17-2020, 10:55 PM | #7 |
Rep 150
Rofl what I wouldn't be happy with that kind of answer. Just go for another one designed for x drive - all other springs I've seen have been specifically designed for rwd or x drive since suspension dynamics are expected to differ.
09-20-2020, 07:08 PM | #8 |
Rep 38
I just finished installing a set of godspeed springs. Drop looks good and ride quality isn't bad. Car is a 535i xdrive. Ill take some pics after they settle.
SikhBMW51.50 SomeMods276.50 |
10-02-2020, 02:47 PM | #10 |
Rep 25
I’m definitely thinking about this springs as well for my 535 xdrive yes take some before and after and let use know about the ride as well, thanks for the info
12-14-2020, 01:37 PM | #11 |
Rep 1,933
12-23-2020, 11:33 PM | #12 |
Rep 262
I can't speak to XDrive but for those of us RWD these springs are killer. Replace the struts when you do it though, I blew a strut within a month so now I'm replacing them all like I should have initially but didn't feel like waiting for the parts.
I have a 550 but they were just as easy as any other spring to install, took me 2 hours or so but I also did brakes and rotors. Mine settled pretty good, I'll have to find my measurements but I had 1.9" drop in the front and 1.5" in the back. I'm sure they aren't going to last as long as other brands but for the past 8 months they have been great for me. I'll find some before and after a tomorrow and post. I recommend.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
12-24-2020, 09:37 AM | #13 |
Rep 538
"Killer" in a good way, or that they killed your struts immediately ^^? lol.
550bye1389.50 |
12-24-2020, 11:38 PM | #14 |
Rep 262
Hahaha, killer in a way of good. I got a pretty aggressive look out of it. Turbos just arrived so hope to have my car back early next week, after I swap my bumpers out I'll take some new pics and post them up.
2011 550i (N63)
12-26-2020, 12:58 PM | #15 |
Rep 262
Pre drop photo. Sorry for multiple posts, the app keeps closing on me when I try to add more than 1 photo and I've restarted it a few times. If you want more, just DM me and I'll send a bunch. But I would give them an 8 out of 10 just because I'm not sure of their longevity but they could easily be a high 9 if they last.
2011 550i (N63)
ezaircon4jc4476.00 SomeMods276.50 |
12-26-2020, 01:03 PM | #16 |
Rep 262
Post drop photo. My turbos are being installed now, so I should have my car back early next week. When I get it back I'll swap my bumpers to the M covers and retake some pics and share.
If you are on a budget or don't care for coilovers, I recommend these. If you are on the fence, go with coilovers. I'm happy with them but if I did it again I would go the coilover route because I want to be able to adjust ride height depending on season.
2011 550i (N63)
01-11-2021, 11:16 AM | #18 |
Rep 92
Well my mechanic couldn't do it referred me to another garage. He said it's due to the control arm adjustment?!?! since it's a xi ?
let's see what this speed shop says' (GEARONE in Exton, PA) waiting on a quote. What should a shop be charging for something like this? recommended a alignment as well. Cheers |
01-11-2021, 08:59 PM | #19 | |
Rep 262
2011 550i (N63)
09-24-2021, 12:54 PM | #20 |
The BMW Life
21
Rep 69
GodSpeed Lowering f10 xDrive
Hi, just wanted to post some info.
Limited info from my research; figured the more out there, the better. The Car: 2014 535d xDrive f10 GodSpeed Kit : https://godspeedproject.com/bmw-5-se...coilovers.html I have 19" wheels with 255/40 rubber, so bigger than stock. Alignment definitely recommended after ANY suspension work. I've set my rear camber to -1.2deg. Front is fixed, and with my setup is sitting at -0.2deg. Ride height is 643mm in the front Ride height is 632mm in the rear Stock lowered "low-slung" for the xDrive is 632/618 stock Stock regular for the xDrive is 641/627 stock These can be changed to whatever you wish. Mine is higher to clear the snow banks Note, that I've had mine down to 610 and turn to turn lock with no rubbing while driving. It's a well designed suspension. (long story short, mine shipped with incorrect shock tubes for the front. |
09-24-2021, 01:00 PM | #21 |
The BMW Life
21
Rep 69
The job can be very time consuming; Install, setup and adjusting, I'd say took me about 8 hours total. That's after having to redo the front shocks completely. ( xDrive is more work to get the OEM fronts out due to the half-shafts )
Also to note, the springs do settle after about a week, so I did re-adjust the height, and got another alignment. Perhaps overkill. I don't have a lift, so a bit frustrating for sure, but worth it when it's all done. If i knew what to set the the coilover height too, I'd saved myself hours. The nice thing about coilovers, beside being able to adjust the tension on the spring, and the height of your car to whatever you like, is you don't need spring compressors to dis-assemble the entire strut assembly. I imagine installing just lowering springs would take less time overall, but you can't fine tune your ride height easily; you'd have to shim. All the being said... I love the way these coil-overs perform. The overall ride feel is great... The car handles amazing on these springs. It actually inspires confidence in the corners vs the OEM setup. It is more bouncy, that's for sure, but I would never go back to stock. My rebound is set two clicks past the softest setting for all four shocks. I might play with that more as they settle in. Cheers, Last edited by COUWK; 09-25-2021 at 05:18 AM.. |
09-24-2021, 01:06 PM | #22 |
The BMW Life
21
Rep 69
You can see from the pictures above; i was shipped the short shock by mistake, the car was almost two inches lower than stock, when maxxed out on the height adjustment.
Info: shock body specs are... 240mm body / 97mm travel (for the short shock) 270mm body / 117 travel (for the longer shock) Factory says 30mm minimum thread engagement on the rear, about 40-50mm for the front. They ship a shorter sway bar link with the kit as well, that is about 40mm less in length The comparison between the OEM and Godspeed is there to see (mind the fact that the height was not set on the coilovers yet) With the correct length shocks installed, the car sits perfect, (it can be adjusted as needed) and it rides very comfortably on smooth roads. There is more road noise transferred to the car when going over bumpy roads, but compared to my e46 and e36 lowering spring setup, by far the best compromise. Cheers, (attached pic is before the correct shock was installed. I had 20mm thread engagement, and a 10mm shim on the top of the strut mount) Last edited by COUWK; 09-25-2021 at 05:36 AM.. |
EV8634.00 |
