09-09-2020, 08:59 AM | #1 |
Rep 126
Drives: 2013 528I M Sport
Stage 2
I am about to go stage 2 and would like some suggestions and links to what hardware I should upgrade aka head cover bolts turbo bolts etc
Tia Matt |
09-09-2020, 11:02 AM | #2 |
Rep 2,590
Stage 2, as in stage 2 turbos or stage 2 tune? Pretty big difference.
2015 BMW 535xi
blkhwkcc18.00 |
09-09-2020, 11:05 AM | #3 |
Rep 126
Both
09-09-2020, 08:59 PM | #4 |
Rep 658
THAT I'VE SEEN- At PS2 power levels you don't really NEED to upgrade any engine internals. It's when you go big single turbo and want to tickle into the 600+ whp area that you may start seeing the limits of the stock internals (depending of course of what year N55 you have as BMW upgraded internals as the years went on).
There's certainly more qualified people than me to guide you in this, but from what I've seen most don't ever NEED to get into the internals. HPFP and LPFP are certainly in your to do list, as well as all the "usual" bolt-ons required for a stock turbo stage 2 tune (catless DP, upgraded IC, CP). Hopefully one of the big HP guys can chime in and lend a hand here. You may want to check out (purely for reference) slowspeed's channel on Youtube. Mike used to have an F10 and now has a 435i with a Big Boost turbo kit. He does a good job at detailing the hurdles he ran into going with this setup. He's trying to push the limits of the engine if that's what you're curious about
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
09-10-2020, 12:40 AM | #5 |
Rep 68
Drives: 2011 535ix M-sport
If you are doing this to a 4cyl, my biggest suggestion is to save the money and go buy a 535 because it will be a much better base and platform for you to tune. You still won't be happy in the end after all that work and paying for other supporting parts when N55s with simple tunes will still be faster.
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
09-10-2020, 10:56 AM | #6 | |
Rep 2,590
2015 BMW 535xi
95blkmax212.50 |
09-10-2020, 02:42 PM | #7 | |
Rep 126
True story
It's paid of off and basically got all the mods for stage 2 for free from friends I know it won't have the power etc My new car is going to be a competition so that will get me the power etc when I crave it but having fun modding the good old 4 cylinder lol |
