2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions P112F and P0171 codes ( air leak ?)
      01-17-2020, 12:43 PM   #1
vV5003
Drives: 2012 528i xDrive
Hi guys ,
It's my first time posting here ,so not sure if this is the right place to post , please relocate my thread if you need.
Just got a beautiful 2013 535i xDrive on 120k miles , black on black and I love the car. However is my first BMW so still learning .
The other day was driving fast in Sports mode , but also was a crazy windy day and got a check engine light. Weird enough , everything was ok while driving , and the light came on only when we started the car and the was an extreme amount of wind at exactly that second. My mechanic suggested it's a cold vacuum leak .
Here are the codes and the advanced data from the app FIXD .
Also for how long can you drive with these codes on ?( I cleared them with the app and they came back after 15 min of driving) Will be able to see my mechanic in 3-4 days....
Will appreciate any help on the topic !
      04-28-2020, 07:21 PM   #2
golfbrah
Drives: tbd
Any luck?
      04-29-2020, 11:21 AM   #3
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Could be a few things. Could be maf sensor. Boost solenoid. Valve cover (which has the integrated pvc built in). Or just a stupid vacuum leak. You can do a smoke test to check for leaks. I'd start there before throwing parts at it.
      05-06-2020, 10:34 PM   #4
vV5003
Thanks guys. It turned out it really is the valve that was causing the problem
      05-07-2020, 02:01 PM   #5
Trainwreck914
Are you referring to the boost solenoid? Glad it worked out. Easy and inexpensive. Thanks for getting back with a fix. That's what makes these forums work
