2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications error code 290900
      11-15-2018, 06:11 PM   #1
ah1301
Drives: Bmw f10
error code 290900
Hi i am having intermittent issues, i keep on getting the engine management sign come up but then it goes away at times then comes back, had the diagnostic test done
Error code which comes up is
290900 - Air system, Air to Egr mass flow, plausibility : measured air mass compared with calculated air mass too high.
i have replaced the egr valve, air mass flow sensor, Valve, EGR exhaust control (EGR EXHAUST VACUUM SELENOID VALVE )
      11-15-2018, 10:24 PM   #2
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
what diagnostic tool did you use?
      11-22-2018, 09:56 PM   #3
mlaraba
Drives: 2013 BMW 535i
looks like ISTA-D.
      08-06-2019, 08:12 AM   #4
brianbelfast
Drives: 2014 320d F30
So did anyone ever get to the bottom of this fault. I've the same symptoms and have replaced the same items. No joy.
EDIT: I finally got to the bottom of this. IT'S CURED !! YAY.
Thanks to all who pointed me in entirely the wrong direction lol.
      09-18-2019, 08:20 AM   #5
1ronm4an
Drives: BMW F30 320D ED
Any joy?
Hi Chaps
Has anyone found a solid fix for this issue, @brianbelfast - i've noticed you've jumped on a few forums - did you ever get yours sorted?
I have an exhaust gas pressure sensor replaced at the tune of £137.60 and still not fixed!
Faults I have are:
290900: AIR SYSTEM, AIR TO EGR MASS FLOW PLAUSIBILITY: MEASURED AIR MASS IN
COMPARISON TO CALCULATED AIR MASS TOO HIGH
28DE00: EXHAUST GAS PRESSURE SENSOR BEFORE TURBINE, PLAUSIBILITY: EXHAUST
GAS PRESSURE BEFORE TURBINE DYNAMICALLY NOT PLAUSIBLE
Any help would be greatly appreciated.
BMW F30 2012 320d ED
      09-22-2019, 05:00 AM   #6
1ronm4an
Hey BrianBelfast
Any news on what you had to change to get this fixed, I’m tearing my hair out and the car was with a mechanic for a week.
Errors 290900 and 28DE00 BMW F30 320d ED 2012
      03-23-2022, 09:26 AM   #7
cunamis
Drives: BMW F11
Guys, I have face with the same fault 290900. What was the solution to it? My code seems to pops up every morning around 10 Celsius degrees.
      12-11-2022, 03:24 PM   #8
jamedi
Drives: F10 520D
hola tengo este mismo fallo 290900 cual fue el resultado y arreglo de la averia
      01-01-2024, 06:30 PM   #9
535d2014
Drives: BMW 535d
Hi Brian, can you post what the solution was to your issue? I’m running into the same problems :/
