2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Brake upgrades from other BMW models on F10
      08-24-2019, 04:19 PM   #155
paul223
paul223's Avatar
Drives: F10
Originally Posted by reihensechser View Post
Originally Posted by paul223 View Post
I wonder if G30 M Performance brakes would fit? I think it's 4 pots brakes for front.
nope, it does not fit. i tried. but it would look really cool.
How about on 20" rims?
      08-25-2019, 08:12 AM   #156
reihensechser
reihensechser's Avatar
Germany
35
Drives: 2016 550i XDrive
the problem is not the the size of the wheels, it's the offset of the caliper. you need a distance plate for the caliper, because the F10 caliper is deeper inside than the G30 caliper.
      08-26-2019, 12:55 PM   #157
addy27
Drives: F10 550i
Adding some clarity here for the folks who are looking to upgrade to 750i or Alpina brakes in the front:
If you have a 550i(USA) AND If you want to upgrade for cosmetics, you can purchase the 750i/760i/ALPINA B7/B6 Caliper Carrier part number: 34216786829 and use your existing caliper housing. You will need to purchase the Brake Rotors for a 750i: 34 11 6 785 675/34 11 6 785 676
If you have a 528i/535i/550i(USA) AND If you want to upgrade for better braking, you will need to purchase 750i/760i/ALPINA B7/B6 Caliper Carrier part number: 34216786829 AND 760i/Alpina B7/B6 Rotors: 34 11 6 789 543/34 11 6 789 544 and pads kit: 34 11 6 794 464
Both of the above mentioned setups use rotors that are 374x36. The difference is that the 760/Alpina rotors have larger surface area since the hat is smaller and the pads are bigger
Lastly, for even better performance with BMW parts, you can upgrade to e70 X5m Calipers/Carriers/Rotors/Pads.. they are bolt on.
All of the above mods have already been done by users on this forum so feel free for further inquiries
      09-13-2019, 02:10 PM   #158
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
You know what would be dope? If the person who created this thread updated the first post with all the confirmed brake kits that fit the f10 instead of everyone having to scroll through the entire thread trying to figure it out. Just sayin.
I heard the f80 m3 brake kit is a direct replacement for the f10. Didnt feel like scrolling through the entire post to see if anyone has confirmed this.
      09-13-2019, 04:44 PM   #159
rcsup1
Drives: x3 35i
Originally Posted by Mike_ View Post
Had this thread bookmarked for a while, shout out to everyone that's put in the work and research. Wouldn't have a clue otherwise.
Typically I made an error with this and mated 760i calipers with 550i discs, giving the attached result, with the caliper housing fouling the disc. Only by 1mm or so, I feel like the caliper could be easily spaced out but I'd rather not.
I was considering my options but can't exactly send the discs and pads back, and I've found 550i calipers which I've ordered, so the 760i ones are surplus to requirements. If anyone is interested in me donating them to their favourite charitable cause, send me a message.
Are you not able to dremel/grind the caliper down a bit where it rubs to make these fit? Seems like it's real close.
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
      09-14-2019, 07:41 AM   #160
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Definitely not.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      09-29-2019, 10:11 PM   #161
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Not sure if this has been discussed in the thread, but I emailed FCP Euro asking if their warranty applies still when you buy 760li brake parts and the such for this upgrade. They said that as long as the parts aren't modified heavily, they'll honor it. Figured this info might help some others.
      10-20-2019, 06:41 PM   #162
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Just for confirmation from those who have done this mod.
The F01 stock 750i front rotors and calipers transfer over to any F10 with no modifications?
No carrier from another model?
This thread is kinda all over the place. Thanks.
IG: @bmwdoubles
      10-20-2019, 09:03 PM   #163
windowmaker
Drives: 2013 550i M Sport 6MT
Any fixed caliper options for "19 wheels?
Edit: Took another read through the thread and apparently E60 M5 may work with F01 37x (374/376?) rotors. Which F01 and does this require the EU spec carrier for the 550?
      10-29-2019, 12:37 PM   #164
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
You will need to buy a new caliper carrier for this mod. You need p/n 34116786829. The carrier you have on your 535i will not work with 550i/750i rotors and calipers. From BMW, the carrier is stupid money, and no one makes it aftermarket to my knowledge. Your best best is to look on ebay for a used one, or check with local salvage yards.
      10-29-2019, 12:46 PM   #165
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
As per this thread, it does appear that E60 M5 front calipers will bolt onto an F10: https://f10.5post.com/forums/showthr...6#post24927566
This thread hasn't really discussed that mod at length, but I don't believe you need a caliper carrier with those E60 M5 front calipers. Either way, I'm not sure you'd get any real improved braking power from that mod, so probably not worth the trouble.
      10-30-2019, 03:23 AM   #166
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I'm slowly acquiring all the parts needed to do the X5M/550i mod. I now have all the calipers and they've been rebuilt and powdercoated. I'm currently pulling my hair out over brake pads and noticed a strange anomaly that I don't think has been discussed on this thread.
Regarding the rear 550i upgrade to 345x24mm rotors and larger calipers, it appears that the brake pads have different part numbers on RealOEM between the US and Europe specs of the cars. The US is 34216857805, while EU is 34216775346.
However, the part numbers for the calipers, carriers and rotors are exactly the same between the US and EU spec cars, so I have to imagine the pads are identical as well, and different p/n for the pads has something to do with the pad compound only.
Can anyone confirm this? The issue I have is that the aftermarket pads I want are only sold in the US (and I live in the UK), so if the US pads are in fact fundamentally different and won't fit in an EU spec caliper, then that obviously will create a problem for me.
      11-01-2019, 03:12 PM   #167
Bayerish Reisenden
Germany
105
Drives: F10 535i M Sport - e31 850csi
So if I understand, we can keep the stock calipers on 535i F10 and take the 750i F01 rotors, brake pads and caliper cariers ?
      11-01-2019, 04:38 PM   #168
jonobro
Drives: bmw f10 535i
Can you link me to the part numbers for the X5M I want to put better brakes on my F10 535i and if they are plug and play like you said why not haha
      11-02-2019, 09:43 AM   #169
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
You are nearly correct. The calipers on your 535i are p/n 34116786817 and 34116786818, which are the same calipers as a 750i. Your brake pads are p/n 34116851269, which are also the same as a 750i. However, you should probably just replace the pads while you're at it if you're replacing rotors.
All the following parts need to be replaced, though:
Front rotors/discs: 34116785675, 34116785676
Front caliper carrier: 34116786829
If you wanted to upgrade to the 760i front brakes, these take different pads (and also have a different caliper p/n as well).
      11-02-2019, 10:22 AM   #170
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I agree that this upgrade is insanely confusing, so over the process of doing this upgrade for myself and weighing different options, I've compiled a document of part numbers, prices, dimensions, weights, etc. This should provide absolute clarity to anyone wanting to do any of the 550i/750i/760i/X5M upgrades to their car.
This was originally in Excel, but I've had to convert it to Word to attach it, so it has lost some functionality. You can PM me and I'll send you the original Excel file over email if anyone wants it.
I'm anticipating that I'll have my X5M/550i conversion installed onto my car by the end of the year, so I'll post some updates on how it goes.
      11-02-2019, 12:01 PM   #171
Bayerish Reisenden
Germany
105
Yes naturally, brakes pads always changed with rotors.
But I have one question, the F01 750i has bigger rotors but the same brakes pads. So that means there is a surface of the brake disc that does not come into contact with the brake pad
      11-02-2019, 01:58 PM   #172
Luky
Luky's Avatar
Drives: 2016 550i M Sport
I have some cleaned up 760i calipers with the taller carriers and bigger pads listed for sale in the classified... just need to add the 374x36mm rotors. (And I would suggest rebuilding them for long term reliability.)
      11-04-2019, 07:29 AM   #173
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I completely understand where you're going with that logic. However, check out post #19 on the first page. I can't really say if there is any truth to this or not, though.
      03-06-2020, 01:32 AM   #174
kennf10
Indonesia
14
Drives: 2013 528i
Has anyone ever buy it from amazon here? Been looking the correct keyword but never find it for my 2013 528i n20.
      03-18-2020, 04:51 AM   #175
Bmw 730d msport
Drives: Bmw 730d f01
I have a question specially in DARKKN1GHT. Can you explain I little more how you fix a front callipers and rotors (G11) in you f10? I have a F01 730d and I will want to put them in a front my rotor is 348x36. Thanks
      07-15-2020, 01:08 AM   #176
Tevzadze2.0
Drives: 2011 Bmw 535 xi
Originally Posted by DARKKN1GHT View Post
Originally Posted by .BMW. View Post
Have you found any 2-piece drilled and/or slotted 374x36 rotors for F01 or F10?
The only ones I found was for E60 M5, but they still might fit.
Would be better with F01 since the part numbers are the same from factory.
https://www.autohausaz.com/pn/34112282805?utm_source=google&utm_medium=cpc&utm_c ampaign=frooglePN&utm_term=34112282805&gclid=CjwKC Ajwq_vWBRACEiwAEReprCUqq90S8ofC4gX7s-xyKNekDfSViq0kdSIJySLwJfKKMHGtspTPzBoCLT4QAvD_BwEThose look like 2 piece M5 E60 rotors which I am pretty sure would fit, same exact dimensions.
Where these confined to fit ?
