2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
04-06-2021, 11:06 AM | #243 | |
Rep 17
Here's what the 7series caliper and 374mm rotor looks like with Style 351m wheels. |
04-06-2021, 12:34 PM | #244 |
Rep 2,591
Any spacers?
2015 BMW 535xi
04-06-2021, 03:11 PM | #246 |
Rep 2,591
2015 BMW 535xi
04-14-2021, 04:06 PM | #248 | |
Rep 17
So to clarify, are you using rear M5 caliper carriers, rear 550i calipers, on 370mm rotors from the F01? Or rear M5 calipers and rear M5 carriers with 370mm rotors from F01? |
04-15-2021, 04:48 PM | #249 |
Rep 175
F01 370mm rear rotors
550i or M5/M6 calipers M5/M6 carriers 550i or M5/6 brake pads The 550i shares the same caliper as the M5/M6. The only sole difference between the two is the fact that M5/M6 painted the calipers blue. The 550i comes in black. You can start with a 550i retrofit with their rotors, caliper, carriers and such which would be an upgrade from the 528 and 535s. Since I have a 550i, I opted to go larger but not break the bank of going full M5 upgrade and use the F01 7 series rear rotors. 370mm is very large so it is a good upgrade and it is widely available. The hardest and most expensive thing on this retrofit are the carriers. You MUST use M5/M6 carriers which would run you 3-500 each side. eBay will be your friend or a German junkyard that they will sell you the caliper and carrier set. Call around, and you might get lucky. I got mines for 300 bucks for everything.....the calipers, carriers, hoses, and even the epb modules. Good luck |
addy27388.00 |
04-15-2021, 09:08 PM | #250 | |
Rep 17
Hey thanks for the info. I do have the rear 550i calipers with the epb modules. Or would I need to buy the epb modules for the F01 or M5/6 ones? Last edited by F10GUY; 04-16-2021 at 01:38 AM.. |
04-16-2021, 08:23 AM | #251 |
Rep 175
The modules are identical.
If that’s the case, source yourself a set of M5/6 rear carriers. F01 won’t have the modules because their caliper setup is different and does NOT use the caliper to function the parking brake. They use the inner drum from the rotor to utilize the parking brake. Just get those awesome carriers and the rotors. Slap em on! |
04-20-2021, 07:04 PM | #252 |
Rep 18
Has anyone tried out the G series *small* caliper (works with 348x36 rotors) on F10? I watched this video on YouTube where it's shown to be feasible, but have yet to pull the trigger:
The fitment in the video looks different from the pictures OP posted, so i'm hopeful that this might be a cost-effective upgrade solution. |
04-21-2021, 12:30 AM | #253 | |
Rep 2,591
https://f10.5post.com/forums/showpos...&postcount=156 Spoke clearance is the main problem. Edit: Huh. Maybe not. They have a photo on their facebook showing a F10 with 374 760 rotors and 374 calipers. Edit: Contacted them and they said it should fit under 343M wheels. I've found a used 748 set off a 750i for ~400, will report back.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 04-22-2021 at 10:22 AM.. |
04-22-2021, 11:06 AM | #254 | |
Rep 18
Did they mention if the 348s would fit the OEM 351M 19’ wheels? If not I can also reach out to them |
04-22-2021, 03:03 PM | #255 |
Rep 2,591
I did not ask, no. But given that 348's are the stock sizes for F10 535's, it'll clear diameter wise. Spoke clearance is the main problem and will really depend on the wheels
2015 BMW 535xi
05-06-2021, 11:00 PM | #256 |
Rep 2,591
They fit under 20" M5 343M wheels. Verified that 18" wheels won't fit. In theory 19" should fit in diameter clearance, since it was just barely not fitting on the 18's. Spoke clearance on a 19" comes down to wheel design and offset. For reference, in the pictures, these are 374 calipers on a 348x30 rotor. They'll actually fit, you'll just need to source smaller pads (or trim them as stated in the video), but I plan on getting 374x36 rotors. Realistically, stopping power won't change too much, I'm pretty much doing this exclusively because I despise the floating front caliper design. Screw that anti-rattle clip.
Gonna get them cleaned up and powder coated. Some misc parts needed as well, such as the 374 rotor shield (or just trim the 348 one, not sure yet lol), stainless steel brake lines, and 550i rear calipers/rotors/yaddayadda
2015 BMW 535xi
Blue Angel999.00 |
05-09-2021, 12:23 PM | #257 |
Rep 2,591
Anyone know if these pins are still good to use, or nah? They have some nicks and pitting, but no major damage outside pin 4's end being a bit chipped up.
2015 BMW 535xi
05-11-2021, 10:06 AM | #258 | ||
Rep 951
X5M calipers on F10..spacer specs
CNH Washer 896-15012 OR Part#: 86625256 (newer part number) https://www.minnpar.com/product.aspx...uctcode=550901 Specs that should work: 13.5MM ID X 28MM OD X 4MM THICK. (FLAT, Metal) |
Blue Angel999.00 |
06-22-2021, 02:50 PM | #259 |
Rep 2
For the people that have upgraded their F10 with 4/6 piston calipers, how is the pedal feel? Just installed 4 piston calipers from a G series BMW, and I`m not so sure that I like how the pedal feels. Have not driven it more than a few miles, and I have not tried bleeding it with ISTA procedure. Just wanted to get some input before I go at it.
06-26-2021, 01:39 PM | #260 |
Rep 1,038
The F10 brake pedal feels mushy even with the small stock brakes. Any increase in caliper piston area will likely (and logically) be accompanied by an equivalent increase in pedal travel.
Has anyone measured the piston sizes on all these different caliper options? |
06-26-2021, 01:44 PM | #261 | |
Rep 2,591
2015 BMW 535xi
06-26-2021, 02:07 PM | #262 |
Rep 1,038
Agreed that introducing air will require bleeding. I'm just saying that even with the stock brakes and having not been disconnected, my 335 brake pedal feels more mushy than firm (I've bled them manually at the caliper). Even after bleeding I would expect a caliper upgrade with more piston area to feel worse than the stock brakes do, all else equal.
Not sure if the M5 has a higher displacement master cylinder or not, but the part number is different: 34336799903 The master for every other F10, including the 550: 34336796729 |
06-26-2021, 03:04 PM | #263 |
Rep 1,127
I see many owners want to improve braking performance yet they choose heavy wheels for their car. BMW OEM non forged wheels weight 28-35 lbs each. I was debating about brakes upgrade but I got forged wheels. Each corner it was 8-9 lbs lighter. Now the car feels lighter, more responsive, more smoother on road, better handling and BRAKING. Depending on personal budget with other mods forged wheels are better upgrade.
jayster0966209.00 |
06-27-2021, 07:26 AM | #264 |
Rep 2
Bled the system again today. Used a rubber mallet to tap the calippers while bleeding with a machine, and some air bubbles got out. Long story short, brakes feel solid now.
