11-13-2022, 06:46 AM | #1 |
![]() ![]() 115
Rep 143
Drives: BMW 535i F10
Which Coolant to use other than OEM
Hello, my radiator started leaking and i have to change it. Went to BMW dealership to buy the coolant but they are out of stock
![]() Started looking for Zerex G-48 and G-05, as i read on forums they are substitutes for OEM coolant but couldn't find them either. My one option is Valvoline HT-12 (green) which says BMW approved, would it be okay to use this coolant or should i search for other options? Any advise on which Coolants can be used other than ones mentioned above? |
11-13-2022, 04:00 PM | #3 |
![]() ![]() ![]() 2777
Rep 5,205
Actually, there are two types of coolant that is approved by BMW. And we have multiple colors now, too…not just the original BMW blue.
![]() We can use G48 or HT-12:
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. ![]() |
lukavergille114.50 CrippledLucifer99.00 |
11-14-2022, 02:55 AM | #4 |
![]() ![]() 115
Rep 143
11-14-2022, 02:35 PM | #6 |
![]() ![]() 878
Rep 2,296
Am I blind or do I not see F10 on that list?
2015 BMW 535xi
11-16-2022, 08:05 PM | #8 |
![]() ![]() 878
Rep 2,296
Which means we should only use blue.
I wonder why there's this strange distinction between 5/6/7 even though they're basically the same cars with the same engines.
2015 BMW 535xi
11-17-2022, 11:25 AM | #9 |
Rep 5,205
No...if that was the case...then you could never take your car to a BMW dealership because they only use HT-12 (green) now.
You can see in the chart that G48 & HT-12 is compatible...they both are nitrate free so it means you can use either the new (green) HT-12 or the old (blue) G48 coolant. I think the only reason the F10/F11 was not listed is because at the time the chart was released...the F10/F11 was at the end of production or had ceased production. the F chasis 6 & 7 series were still being produced. Take note that they don't have any E nomenclature models listed (which were not being produced at the time the chart was released).
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. ![]() Last edited by Qsilver7; 11-17-2022 at 11:32 AM.. |
11-17-2022, 02:56 PM | #10 | |
![]() ![]() 878
Rep 2,296
As for the 6/7 thing - I don't think this is true. The F gen 7 series ended with the 2015 MY. The F gen 5 series ended with the 2016 MY - meaning, the 7 series stop being produced before the 5 series.
2015 BMW 535xi
11-18-2022, 11:17 AM | #11 | |
Rep 5,205
The top chart that mentions the F gen models (that used the old blue G48 coolant) have production dates that end sometime in 2018...then the chart showing the new HT-12 coolant...also have production dates in 2018 upward...so again, this would seem to exclude the F gen 5 & 7 since their EOP was in 2015 & 2016 respectively.
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. ![]() Last edited by Qsilver7; 11-18-2022 at 11:32 AM.. |
11-20-2022, 01:41 AM | #12 |
![]() ![]() 1140
Rep 1,017
Drives: 2006 BMW 330i MT
Would mixing G48 and HT12 be okay? Like topping off HT12 with a half gallon or so of G48?
Asking for a friend... |
11-20-2022, 03:56 PM | #13 | |
Rep 5,205
StradaRedlands1140.00 |
11-20-2022, 04:29 PM | #14 |
![]() ![]() 1140
Rep 1,017
Based on the pictogram, I'd say both are usable in the vehicle. And am working on the presumption that they can be mixed. But am hoping for confirmation from random people on the internet!
11-22-2022, 02:05 PM | #15 |
![]() ![]() 878
Rep 2,296
It's a valid point. Just because they're interchangeable doesn't necessarily mean they're inter-mixable. I'd just go with whatever is currently in your car, and if you want to switch, drain the old one first.
2015 BMW 535xi
