2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications LPFP upgrade
      04-03-2018, 07:02 PM   #1
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
LPFP upgrade
As of late I've been tooling around knowing I was out of fuel and I had more power on the table supported by my mods, but again... I can't feed the boost.
First step in that department is upgrading the LPFP. The F10 N55 cars use a TI Automotive form factor pump so the Walbro/TI Automotive 450LPH pump looked to be a direct swap in.
For less than $100 its a no brainer to knock this one out myself, rather than pay the $400+ Fuel-it or the like fetch for a ready made pump already converted.
Anyway, tackled this project last night and took a few pictures.
Lock ring tool, absolutely required to get it open. The amount of torque needed to release the ring was staggering.
Upgraded 450 LPH pump on the left, stock unit on the right
450 LPH pump drops in place of the stock, fits the housing, fits the filter sock. Zero modifications needed. I crimped spades onto the wiring and inserted them into the factory connector. 100% reversible if and when I wanted to.
SC300T26.00
ssgm1x418.50
gabypr150.00
Ickdeep5720.50
      04-04-2018, 01:06 PM   #2
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
Great pics. How hard was this to remove ? Definitely need the tool to remove. Was thinking of changing my pump. Mine is gurgling when below 1/2 tank of gas.
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      04-04-2018, 01:12 PM   #3
Stück
Stück's Avatar
It was "Either its going to pop free and go flying or the fuel tank is going to break" tight.
I made a grave miscalculation doing this at 3/8th of a tank of fuel as well. I lost at least a gallon or two the shop floor. Wait until you have 1/8th or the range warning up to do this.
Removal of the fuel pump assembly from the tank was simple enough it all unclips and snaps back in.
      04-04-2018, 07:14 PM   #4
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
Any guess what this LPFP upgrade gives you in terms of supported wheel horsepower? 450whp maybe?
      04-04-2018, 08:20 PM   #5
Stück
Stück's Avatar
The BOSCH HPFP is the limiting factor now. 450whp on the stock HPFP isn't realistic. Early style Continental no problem as it was shared with the N54. The BOSCH style is better, more reliable but has less fueling headroom than the Continental it replaced.
I'm working on a solution for that though. I have a complete S55 dual pump HPFP setup at the shop, will be retrofitting to my N55 soon that will give me 600+whp fueling support.
The LPFP upgrade is to provide enough volume support to the dual HPFP incoming.
      04-04-2018, 08:31 PM   #6
AZ-MCRacer
AZ-MCRacer's Avatar
306
Drives: 2022 G82 M4, 2013 F10 N55
Nice documentation. I was definitely more of a hurry when I did my PS2 and went with the Fuel-It Solution, which is essentially the same thing. I also upgraded my fuel line from the pump to the split between PI and the stock HPFP. I also added an inline Ethanol sensor.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD!
1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped
      04-05-2018, 07:50 AM   #7
Stück
Stück's Avatar
You keep asking us for videos, there is really nothing to hear different at least not that is going to be picked up on a video.
      04-09-2018, 12:05 AM   #8
mikehong918
Drives: 2011 BMW M3
Thanks for posting this! Did this last night quick and easy switch. Definitely should of waited till gas tank was low.
      04-10-2018, 11:56 AM   #9
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
taking notes
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      04-10-2018, 08:59 PM   #10
ssgm1x
ssgm1x's Avatar
Where did u order new pump motor from? Part number ? May do this myself also
      04-10-2018, 10:42 PM   #11
mikehong918
Drives: 2011 BMW M3
The one stuck used is f90000274
I bought mine from amazon F90000267 which is a slightly lower max pressure before the relief valve kicks in.
Both has the same flow rate and dimensions.
2014 535i - ER Catless DP, VRSF Charge Pipe, M Performance Exhaust, BMS WMI, 450LPH LPFP, Wagner FMIC, JB4, N20 TMAP, Pure Stage 2 - To be installed
gabypr150.00
      04-11-2018, 05:01 AM   #12
JakOG
Drives: 2011 535i MSport
DO you know which cars ran this earlier continental pump?
      04-11-2018, 09:34 AM   #13
Stück
Stück's Avatar
Early production N55 are Continental, not sure on the production split. Completely different pump architecture and easily identified visually without taking anything apart.
      04-11-2018, 08:59 PM   #14
gabypr
gabypr's Avatar
Puerto Rico
150
Drives: Jet Black 2015 F10 535i
Very interesting. Subscribed.
CQuartz UK 3 Ceramic Coating | GeoShield Pronano 50% Ceramic Window Film | M5 M Perf Steering Wheel | M6 Comp Pkg Mufflers | M Perf Floor Mats | CF Spoiler | RW CF Quad Setup Diffuser | RW CF Front Lip | CF Trim | BMW Interior Leds | M5 343 Wheels | Pure Stg 2 Turbo
      07-21-2018, 01:17 AM   #15
tcabill
tcabill's Avatar
Drives: e63 650i, F10 535i, E93 335i
I'm in the middle of doing the upgrade with the Walbro f90000274. Bought a bunch of AN and other assorted fittings based on what I read on other forums when all I needed was the pump and this
http://www.radiumauto.com/Submersibl...bing-P672.aspx
Also, a big flattip screwdriver and a swing wrench (aka Hammer) was all it took to get the ring off. In the morning it will all go back together with 3/8" PTFE fuel line from pump to inline sensor then on to HPFP. Not even close to the hassel I thought it would be, easy peezy.
      07-21-2018, 06:18 PM   #16
tcabill
tcabill's Avatar
Done
Finished this morning and filled up with e85 (tested at E78). Runs like a champ, getting ready to analyze my logs but I don't expect any surprizes there. I'm running FBO with stock turbo, I just reset adaptions and did a few pulls and it runs fantastic.
      07-29-2018, 11:15 AM   #17
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I just had the dealer replace my LPFP on a recall, but for 100 bones it's worth doing it agin
IG: @bmwdoubles
      07-29-2018, 12:06 PM   #18
$howtime456
301
Drives: BMW 640i
Ordered one from a company i would not like to mention. Sent me the wrong one. Just returned it and now going to do this myself. Stuck where did you get the lock ring tool at?
N55 GENERAL
David Shoup Tuned
Hoa512.50
      07-29-2018, 02:15 PM   #19
Stück
Stück's Avatar
The one pictured above is a Baum Tools P/N 161190. It was ordered from Baum, but there are likely plenty of resellers out there.
      09-08-2018, 09:26 AM   #20
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
No blend just pure e85 full tank?
IG: @bmwdoubles
      09-08-2018, 08:04 PM   #21
paul223
paul223's Avatar
Drives: F10
With this pump, can you run straight E85? I have stage 1 turbo.
      09-09-2018, 04:00 PM   #22
etnsandman
Drives: 2015 M5 Competition
I'm doing this upgrade Friday since my stock lpfp is throwing errors. Thanks for posting this DIY. Headed to e40 town soon. ��
