2010 2011 BMW 5 Series Forum F10 Is 6WB HUD cluster fit F10 without HUD |
03-25-2018, 07:14 AM | #1 |
Rep 72
Hello all,
I have F10 2011 without HUD and need to change the cluster from 6WA to 6WB There is any problem if i install HUD 6WB cluster? Will get any error because not connect HUD? Appricate your help Thank you |
03-26-2018, 02:16 PM | #3 |
Rep 72
03-26-2018, 03:28 PM | #5 |
Rep 72
12-16-2019, 02:49 PM | #6 |
Rep 423
Sorry to dig this thread back up, but I am thinking about upgrading to a 6wb cluster and have a few questions.
Are there variants of the 6wb cluster that will fit the f10 or are all of the 6wb clusters the same. In other words, do I need to look for a specific donor car? I have been trying to research the swap and have come across a few G30 6wb clusters that I would love to pick up, but I'm not sure if the G30 cluster will fit. It seems like my current F10 cluster has a "hood" that spans over the top of the cluster that does not seem to be present on the new G30 6wb cluster. |
12-16-2019, 03:25 PM | #7 |
Rep 7,480
Use one of the online part database sites...you can look up the two 6wa and 6wb clusters...then click on the 11 digit BMW part nbr and it should list all other BMW models that use the same part nbr. That way you'll know what donor BMWs you can use.
The 2nd pic you posted looks like the new style cluster used in the new G chassis BMWs...where just looking at the two outer (smaller) gauges indicates that the cluster isn't compatible with the F chassis. The F10's 6wb cluster has 4 circular gauges that are open on the side...whereas the f10's 6wa cluster has 4 circular gauges that are open on the bottom (almost like a horseshoe). {6wa cluster} {6wb cluster}
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-16-2019 at 03:31 PM.. |
12-16-2019, 03:47 PM | #8 |
Rep 423
Thanks for the quick post. I will give that a shot.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
12-16-2019, 04:03 PM | #9 |
Rep 7,480
No problem...using the www.realoem.com website...and using my 2013 f06...I get these possible donor BMWs for the 6wb instrument cluster. And you can also see multiple BMW part nbrs that have been used during the production run of these BMW models.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
12-16-2019, 04:37 PM | #10 |
Rep 423
Awesome. That really helps.
10-19-2021, 06:47 AM | #13 |
Petrolhead
440
Rep 808
Yes, it would have an extra plug inlet on the back (light beige if I recall correctly).
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
Tags |
6wb, f10 |
