03-16-2021, 04:57 PM | #155 |
![]() 26
Rep 81
Bringing this back because I think I accidentally bought m6 343m wheels for my f10. Downsized the tires from 295 to 285 thinking this would've made it more flush but it still sticks out quite a bit. The car rides smoothly and I usually never have many people with me so rubbing isn't an issue. Is it safe to keep running this set up?
03-16-2021, 07:47 PM | #156 | |
![]() ![]() 986
Rep 2,400
2015 BMW 535xi
03-16-2021, 09:07 PM | #157 | ||
![]() 26
Rep 81
03-17-2021, 12:23 AM | #158 | |
![]() ![]() 986
Rep 2,400
There's really no reason you can't unmount the tires and mount them on M5's, the tires will fit fine. You'll just need to go through the hassle of selling your old wheels.
2015 BMW 535xi
11-26-2021, 02:31 PM | #159 |
![]() ![]() 27
Rep 64
I just bolted on OE 343M wheels to my 2011 550i MSport with stock suspension for a test fit.
Tires are 305/30/20 and 275/35/20. No need for spacers anywhere. There are about 5-6 mms to the front caliper from the rim center/hub. I don't see the caliper deflecting that much under load. I tried a few hard stops and no marks on the caliper or rim. I think the 343m rims are perfect for this car as is. The 305 tires seem like they *may* clear the fender if camber changes favorably under compression but I did not drive the car long enough with people in it to test. I see that some posters reported 295s rubbing but not sure about the F10 model (and if the hub spacing is different on a 550i compared to other models). I am planning to go with 295/30 and 265/35. I will have the rims finished back in OE machined silver first; don't like the all black look. UPDATE: I replaced the front hubs because the bearings were done and the front wheels rubbed slightly on the calipers. Either the new hubs were speced a bit differently(more likely) or whatever corrosion/dust was on the previous hubs acted as a spacer by 1-2 mm (I doubt it). So, I had to get 3mm spacers and they work fine.
![]() Last edited by lucid21; 11-26-2022 at 07:01 PM.. |
EV8625.50 |
12-26-2021, 09:49 AM | #160 |
![]() ![]() 27
Rep 64
I had the wheels powder coated champagne. Looks much better than black. Winter tires on; 265/275. These wheels are perfect for the 550 and will also look good on my M5. And, yes, I can actually feel the weight difference compared to the OEM 20" cast wheels.
12-27-2021, 09:38 AM | #162 |
![]() ![]() 27
Rep 64
Agreed. 265/285 would also look fine. 275/305 was too much indeed.
01-13-2022, 12:43 AM | #163 |
Rep 12
M5 343M wheels are a perfect fit for the 535i M Sport. For the aesthetics of matched diameter and sidewall height I chose 255/295.
Front: 255/35/R20 Rear: 295/30/R20 ![]() ![]()
2011 BMW 535i 6 Speed Manual RWD in Titanium Silver Metallic and Black Nappa Leather Interior with M Sport Package Premium Package 2 Chrome Delete
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34 Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20 Last edited by MuonShowers; 01-17-2022 at 12:02 AM.. |
01-13-2022, 08:56 PM | #164 | |
![]() ![]() ![]() ![]() ![]() 594
Rep 815
What tires are those? They look pretty stretched for a 295 on a 10" wheel. I ask because your fit looks great, but most people with 295 rear on 343m have rubbing issues and have to add camber to clear. Last edited by Blue Angel; 01-13-2022 at 09:16 PM.. |
01-16-2022, 03:11 PM | #165 | |
Rep 12
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34 Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20 Last edited by MuonShowers; 01-16-2022 at 04:45 PM.. |
01-16-2022, 04:36 PM | #166 |
Rep 12
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34 Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20 Last edited by MuonShowers; 01-16-2022 at 08:31 PM.. |
Blue Angel594.00 |
01-16-2022, 09:25 PM | #167 |
Rep 815
Aha! You did exactly what I was going to do - head to Tire Rack for some stats, I presume?
![]() Well, using a narrow 295 is obviously a great fitment on 343m! ![]() |
01-24-2022, 07:54 AM | #168 |
Rep 6
03-03-2023, 10:27 PM | #169 | |
![]() 15
Rep 145
04-02-2023, 12:14 AM | #170 | |
![]() 15
Rep 145
07-15-2023, 12:32 AM | #171 |
![]() 3
Rep 58
Dont mean to bring up an old thread but i have a 2016 bmw 550i xdrive awd with the dynamic handling package, i was wondering i need spacers for the front rims to fit?
Also what size tires would i need? |
08-15-2023, 04:16 PM | #172 | |
![]() 15
Rep 145
https://www.ebay.com/itm/22351678066...QwZe6ySyIi3LAo |
