2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Tune for only sport+ mode?
      06-01-2023, 03:27 PM   #1
KevinD.Bonds
Drives: BMW X3 2013 x28i
I drive a 2016 BMW F10 550i
I live in a quiet culdesac, I’m just wondering if it’s possible to have a performance tune/flash burble tune/whatever tune on specifically the sport+ mode.
Or if it’s possible to enhance the sport+ mode somehow. Essentially I just want a stock untuned car normally for when I’m in town or whatever. Then a loud fast monster car when I put it in sport+. Another idea is to have a button that turns the burble tune ON/OFF on the dash or something.
I already have an electronic control exhaust valve being installed too
      06-02-2023, 04:13 PM   #2
tevad
Drives: 2014 BMW 535i - Sophisto Grey
I believe with the BM3 tunes you can adjust the burbles and throttle response delay based on the driving modes. You could do the throttle response delay on Comfort and Sport, but leave it off for Sport+. Same with the burble intensity. You should be able to turn it off except for Sport+.
I'm only Stage 1 on my non-M 535i, but I saw those options in there. The extra power throughout the mid-range is incredible.
      06-03-2023, 11:49 AM   #3
Double Nickel
Double Nickel's Avatar
Drives: BMW F10
2015 BMW F10  [10.00]
535i MHD you can control it how you want, i too run a valved exhaust but i also run sport mode every drive wit the valves closed mostly.
      06-03-2023, 12:53 PM   #4
SWFLf10
SWFLf10's Avatar
I could be wrong, but I believe you could switch maps using bm3 using you’re steering wheel controls. This way you could have set to stock when you want, or switch to a more aggressive map when you want.
I may be wrong about that, but worth looking into.
      06-03-2023, 01:43 PM   #5
Double Nickel
Drives: BMW F10
MHD you can👍🏾
