2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Creaking sound from front suspension/axle
      08-09-2022, 08:02 PM   #23
zvery777
zvery777's Avatar
Drives: 2016 BMW 535ix
2016 BMW 535ix  [0.00]
Bump!
      12-01-2022, 02:29 PM   #24
zvery777
zvery777's Avatar
Since my door seal was recently replaced and the rattling door noise is still there, I'm thinking to replace both highlighted parts from this diagram. #8 seems easy enough but has anyone replaced #3? Is it difficult?
      05-08-2023, 02:07 PM   #25
zvery777
zvery777's Avatar
Replaced the parts mentioned above and the door noise is till there. Will keep on researching!
      05-10-2023, 07:15 PM   #26
SummerallGuard04
SummerallGuard04's Avatar
39
Drives: 2016 BMW 550i M Sport
I sure am glad i found this thread--i just started noticing a creaking, metallic click sound coming from my front wheels. I can faintly hear it when i turn the steering wheel back and forth. It is not loud at all so I can't think it is a bad control arm or ball joint. I googled it and found a very interesting youtube video that aligned with my symptoms.
So, according to the video...it's the control arm ball joint nuts that are not tight enough. (sound is not coming from control arm, it's coming from ball joint).
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black
2011 BMW 335i - Alpine White
      05-10-2023, 07:45 PM   #27
zvery777
zvery777's Avatar
Originally Posted by SummerallGuard04 View Post
I sure am glad i found this thread—i just started noticing a creaking, metallic click sound coming from my front wheels. I can faintly hear it when i turn the steering wheel back and forth. It is not loud at all so I can't think it is a bad control arm or ball joint. I googled it and found a very interesting youtube video that aligned with my symptoms.
https://www.youtube.com/watch?v=qblIczXQgTE
That's very interesting but my noise does not sound like this. I used to have clicking when turning and there was a SIB for it to add these friction discs between the rotor and wheel hub. Will keep in mind to check these bolts next time tho just in case. Cheers!
      05-10-2023, 09:47 PM   #28
SummerallGuard04
39
Do you have a link for the SIB?
      05-10-2023, 09:52 PM   #29
zvery777
zvery777's Avatar
https://static.nhtsa.gov/odi/tsbs/20...84575-9999.pdf
It's not for F10 but apparently it fixes the clicking sound and my dealer did not charge me for it. I can dig in my paperwork if you need anything additional.
      05-10-2023, 09:54 PM   #30
zvery777
zvery777's Avatar
https://www.2addicts.com/forums/show...1283009&page=2
This thread might be helpful also
