2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Burnt oil smell and smoke from exhaust
      05-20-2023, 01:27 PM   #1
Cullen550ix
Cullen550ix's Avatar
Drives: BMW 550i xdrive
I’ve got a 2016 550i with around 85k miles. I’ve recently replaced the crank case ventilation system because it was broken and I thought was the cause for all the burnt oil and smoke. It has since become a lot better. But I’m still having white smoke from the exhaust at idle and the car smells of burnt oil. I’m losing about 3 quarts of oil between intervals. Any ideas what it could be?
2016 BMW 550i xdrive. ARM catless downpipes, ARM intake system, Jb4 tune
      06-15-2023, 05:41 AM   #2
SamirSami
Iraq
Drives: 09/2012 F10 530i/N52B30
valve stem seals
      06-15-2023, 12:52 PM   #3
SWFLf10
SWFLf10's Avatar
This is a known issue with the valve stem seals getting brittle and letting oil leak by. The BMW N63 V8 engines are know for this. It seems to be less common with the N63TU versions.
It may not do anything, but I add some Liqui Moly Oil Saver during my oil changes to help keep the rubber seals from drying out. Worth a shot in my opinion to see if it help at all with lessening the issue.
