2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2012 BMW 535i Spun Rod Bearing
      06-01-2021, 06:36 AM   #1
tbrecht
Drives: BBW 535I XDrive
Last week I started to get a knocking noise in my MY2012 535i XDrive. After discussing with my mechanic, we are 99% sure it is a spun rod bearing.
Now I am faced with a couple options...
1. Replace with remanufactured motor.
2. Replace with used motor.
3. Sell car and move on.
The car has about 168k, on essentially entirely stock setup. I've owned it since 104k almost 3 years ago, and have been meticulous on maintenance since I've owned it (OFHPG in last 2k miles, Valve Cover, spark plugs, and rear suspension replaced in last 15k miles, Oil changes every 7-8k, new brakes/rotors, bearings, Water Pump in last 20k, HPFP in last 60k, etc.). The car is clean inside and out, just a couple small dings and wear here and there.
Knowing that the majority of the rest of the car is *knock on wood* mechanically sound and maintained, I am at a tough decision of how to proceed. Comparable, (2-3 years newer, ~100k miles) are selling for about 7k more than I paid for this one.
I have an independent foreign auto shop that will swap the motor in for a good deal, I just would like some advice if anyone has had any luck with remanufactured or used motors. I drive about 20-25k miles a year, so I am hoping to get something reliable.
Has anyone had any luck with either remanufactured or used motors? I am located in the Grand Rapids, Michigan area, and would likely need to have one shipped in from somewhere else.
Thanks for the advice!
      06-01-2021, 08:18 AM   #2
Cvx5832
Drives: ‘15 535i M-Sport
No insight on the used motor but I find it interesting that the OFHG was done in the last 2k miles. The evidence seems to be piling on with the need to prime the system.
To be sure, did you follow the priming procedure after that gasket replacement work?
      06-01-2021, 08:42 AM   #3
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Sucks to hear. The n55 is still usually very reliable at high mileage, given proper maintenance. As mentioned, the recent oil filter housing gasket job may be associated to this failure.
I would keep the car and change the motor, if able to source a good one, and the Indy is well competent. It beats a car payment..! And your f10 still looks great.
otay826.00
      06-01-2021, 09:37 PM   #4
Hoa
I think the recent OFHG job may have caused the motor to fail. If proper procedure is not followed, your motor will run dry for a few seconds and eventually cause the motor to fail.
If you like F10 platform, I'd recommend a low miles motor replacement and it will last you a very long time. It would be worth it if motor and labor is 4-5K in total. When putting in a motor, please replace all gaskets to avoid any future leaks. If water pump and thermostat haven't been replaced, now is a great time to throw in a new one as well.
      06-02-2021, 12:58 AM   #5
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
I doubt it's directly related, correlation is not causation. A single dry start up event in the grand scheme of things should not cause a spun rod bearing. Even then, it's not like the engine is bone dry when you drain the oil. There's still going to be oil trapped in various passages.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      06-02-2021, 05:00 AM   #6
tbrecht
Thanks for the input everyone.
As far as the OFHG, I left the oil in while I changed it, then drained and replaced after the entire housing was back in place. I wouldn't have expected that there should have been concern about priming it if I left it in the old oil before it sat for a couple of days.
Now onto finding a motor... Not having much luck for something under 100k miles on it. I think I'm going to search for about another week to see if something else pops up.
      06-02-2021, 11:20 AM   #7
otay
otay's Avatar
Drives: 2015 335i
Nice F10. Just asking...
How do y'all know it's a spun bearing? Does it turn over? If it turns over...maybe a rebuild of your current N55?
      06-02-2021, 06:18 PM   #8
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
If the engine still runs then I would sell it to Carvana. 10/10 recommend.
Other than that if you are driving a lot find a good used motor from a LCI F10 and swap it in. The only issue is that when I was looking for engines when my engine went bad N55s were going for about 5-6k used which did not make financial sense for my car. Generally rebuilt or refurbished engines are complete junk and I know a lot of repair shops that will not install a rebuilt engine.
      06-02-2021, 07:47 PM   #9
beegeezy
beegeezy's Avatar
70
Drives: 2013 535i M-Sport
I’ve shared this website before: https://www.car-part.com/cgi-bin/sea...erPage=1&iKey=
Plenty of <100k engines for under $5k out there
      06-02-2021, 09:15 PM   #10
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
That's tough. Given the mileage car is only worth 7k on a good day. With a good engine. But as others suggest. Either find a good donor. Or cut loses.
      06-03-2021, 06:25 AM   #11
tbrecht
Definitely did not see this site before. Thank you!
      06-03-2021, 11:51 AM   #12
Unspec
Unspec's Avatar
1301
car-part.com and lkq are the go to places to find salvage parts. It's just a bit tricky finding out what certain parts are labelled as, as sometimes it's not super intuitive, but you get the hang of it quickly.
2015 BMW 535xi
      06-07-2021, 06:45 AM   #13
tbrecht
After lots of consideration and shopping around, I am going to go with a used motor to replace it.
The shop found one from a rear-end wreck with 89k on it shipped to me for $4.5k. Got quoted $2k to put it in, including about $500 estimated for fluids, and stripping it down and replacing gaskets, bearings, and other items in the used motor.
Should be right around $6.5k +/- a couple hundred out the door. Best of all, no core charges. The motor comes with the turbo, and all accessories to sell or keep as spares.
I looked at a remanufactured motor. The plus for that is that it came with a 2 year warranty, but I wasn't impressed with the requirements that came with it. Also, the core charge came up to $1.5k, +$400 shipping. Seemed kind of wasteful to spend $400 to ship it down there, with only potentially getting $1.5k back (best case $1.1k for the core seemed sort of low, but I guess it is only for the long block, without any accessories).
I'll post back when it gets installed, and what I come across...
      06-07-2021, 11:34 AM   #14
OnlyGerman
OnlyGerman's Avatar
6-7k is better than a car payment for 48+ months!!! And I hope you get another 100k out of this investment
      07-01-2021, 06:30 AM   #15
tbrecht
Update on where everything ended up...
I got the car back from the shop four days ago, and put about 300 miles on it. So far, running great.
I got a used engine with 96k on it, and unlimited mileage 2 year warranty for parts and labor. Engine came with all accessories on it.
The only snag with the swap was the AC condenser started to leak when it fired up. Replaced that and all is running well. Total cost was just over 8.7k, and $250 for the core charge. Hoping to recoup some of it by selling the left over parts online.
      07-01-2021, 07:26 AM   #16
OnlyGerman
OnlyGerman's Avatar
8.7 sounds high for a used engine replacement, no?
      07-01-2021, 08:47 AM   #17
philipm785
Drives: 2016 550i
Glad you got it all worked out. Obviously a little more money than you'd initially thought, but the two year warranty is a huge plus and I'm sure you'll recoup some cost from re-sale of turbos, etc. Hope you continue to enjoy the car!
Edit - just looked back at the picture in the first post and can see at least one more reason why you kept it - that thing is beautiful!
      07-01-2021, 11:34 AM   #18
Unspec
Unspec's Avatar
1301
Prices are up because of covid. Less cars available for purchase = more repairs, which tends to drive up prices of used engines.
2015 BMW 535xi
      07-01-2021, 01:41 PM   #19
tbrecht
It was a little bit more than I expected. The ac condenser, plugs, and list of gaskets and fluids really added up. I hadn't accounted as much for those adders before hand.
I had found a couple of motors for around 4500-5500. Coming with all the accessories and the warranty convinced me. Hope I never need it.
Tags
535, engine, f10, knock, rod bearing
