2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Guess it was a bird?
      12-16-2017, 05:50 PM   #1
Brian Edward
Drives: 2013 528i twin turbo sedan
Question Guess it was a bird?
Any tips on how to repair this?....It seems to have gotten bleached out by something....Thks!:
      12-16-2017, 07:11 PM   #2
Bird poo is VERY toxic to automotive paint. I learned this years ago when my wife let the stuff sit on the paint for a couple (maybe more; I was at sea) weeks and it left an ugly discoloured area. That said you can try buffing it out but you may end up having to replace the pieces.
      12-17-2017, 07:34 PM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
looks like someone with toxic spit?! take a buffer to it...probably finishing compound
      12-18-2017, 08:48 PM   #4
Brian Edward
Good idea's
Thanks for the reply's!!
      12-21-2017, 06:22 AM   #5
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
Because of the matte finish on those B pillars, I'd think twice before hitting them with a machine and compound/polish.
Personally I'd be very inclined to try chemical or non-abrasive means before resorting to abrasives, lest you change the appearance of the finish permanently.
You could try clay or synthetic clay mitts, some APC (with a water rinse) on microfiber, a non-abrasive pre-wax "cleaner" (something like the old Zymol HD Cleanse or P21S paintwork cleanser come to mind) and such.
I haven't faced this particular challenge, but I had decided to machine polish/compound the matte B pillars on my E39 to remove oxidation and ended up with "semi-gloss". In my situation, I expected this, but that may not be what you're after.
      12-21-2017, 07:52 AM   #6
Quicksilv3r
Quicksilv3r's Avatar
Drives: 2013 BMW 535i M-Sport
I think it'll be fine with a machine polish. Those pieces are solid plastic, nothing but more black plastic underneath.
-WJV
      12-21-2017, 08:42 AM   #7
Surly73
Oh - plastic? I'm thinking of past BMWs where it's metal so maybe it's not a big deal.
For clarity - I was not cautioning against going through the finish, but changing it to something more glossy than it originally was.
All that being said, if it's truly plastic, with colour all the way through, I'd definitely use APC or degreaser and a microfiber cloth or fine brush first.
      12-22-2017, 08:55 AM   #8
Quicksilv3r
Good point, I would bet it would make shinier. Just do the other side too so they match
-WJV
      12-23-2017, 11:35 AM   #9
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
If none of the above works, how about just wrapping them in some vinyl wrap? Matte finish if you want to keep the same look or get gloss black to look more like msport pillars. Materials for this should be ~$10.
      01-04-2018, 08:08 PM   #10
Brian Edward
B-Pillers
If I ordered a couple new ones for that side, that is what there called?......Are they relatively easy to take off?.....Thx!
      01-05-2018, 12:48 PM   #11
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
Should be #14 on here.
You just need to figure out what yours is.
My guess is the first one, the rest are gloss black
http://www.realoem.com/bmw/enUS/show...diagId=51_7922
If you try to rub or polish it will get glossy.
      02-18-2018, 07:54 PM   #12
740boy
Drives: 2011 535i sport
I would try with the least aggressive polish first.
      02-20-2018, 09:01 PM   #13
snj1013
Drives: 2011 528i
Pretty sure you’ll need to wrap or repaint to fix this.
      02-20-2018, 09:14 PM   #14
Any update??
      02-21-2018, 09:17 AM   #15
lsturbointeg
Any update??
i was thinking of wrapping mine in carbon fiber vinyl?
      06-04-2018, 09:12 PM   #16
Brian Edward
Changed it out
Bought a new piller cover, once I figured out how it came off, no problem!
