2010 2011 BMW 5 Series Forum F10 F11 6NK + snap-in adapter |
07-17-2018, 08:06 AM | #1 |
Rep 9
Hi all,
I have a 2013 F11 with the following:
Recently a iPhone 5 snap-in adapter landed in my hands and as I had an older iPhone 5 laying around I have decided to try use it as a mediaplayer / hotspot through the snapin adapter. To my surprise, inserting the snap-in adapter did absolutely nothing, I cannot see it in the 'External devices' menu - just like it would be the basic snap-in (only charge and antenna). I have checked the model number - 84212289718 - and is the Connect model that should also have USB media. Do I need to code something? Tried coding 6NS however the snap-in still not in the 'External devices' menu and more to it I have lost the BT audio option (only calls and data). PS. I have an NBT unit and no combox Last edited by aTasca; 07-17-2018 at 08:20 AM.. Reason: Additional info |
07-17-2018, 10:37 AM | #2 | |
Rep 5,337
07-18-2018, 12:42 AM | #3 |
Rep 9
07-18-2018, 06:38 AM | #4 | |
Rep 40,659
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-18-2018, 12:33 PM | #5 |
Rep 9
Hi Shawn, thx for your answer, I have added 6NF to FA and VO coded NBT and I can now see the snapin symbol in the 'external devices' menu .
However when I attach the snapin and the phone, nothing happens. Do I need to do some extra coding? I noticed that even attaching the iphone to the central console USB port via cable, I still cannot see it in the devices list. On BT all works fine. I have attached the snapin and the phone to a LCI F10 and it got immediately detected and working Thanks again. |
07-18-2018, 12:41 PM | #6 | |
Rep 40,659
Make sure to FDL Code these: HU_NBT => API_IPOD_VIDEO = both HU_NBT => API_USB_VIDEO = both If you are looking for the "Plugin" function, BMW AG killed it off long time ago when Lightning Connector was introduced as it is all Digital with no analog out.
07-18-2018, 12:47 PM | #7 | |
Rep 9
I have the plate and the iphone snap in adapter. I am looking to play the iphone audio library over the snap in connector and not via BT.
Will try coding what you have suggested and report back Thanks. Quote:
07-18-2018, 01:29 PM | #8 |
Rep 5,337
I don't remember where I had to code (KOMBI maybe?? Shawn??), but I had to change "analog" to "digital" when I got my first adapter for our 2012 535i. It responded just as you described until I made that change.
I'll do some digging and see what I can find... |
07-18-2018, 01:36 PM | #9 | |
Rep 40,659
HU_NBT => USB1_IPOD_AUDIO = AUTO HU_NBT => USB2_IPOD_AUDIO = AUTO
07-18-2018, 01:43 PM | #10 |
Rep 5,337
I don't know the module, but try this:
From: USB2_IPOD_AUDIO analog To: USB2_IPOD_AUDIO digital https://www.e90post.com/forums/showthread.php?t=883763 EDIT Try this: Under HU_NBT (ECU) You need to read the Code and FDL code this entry. HU_CIC/HU_NBT 3003 TELEFON_TELEMATIK_ONLINE USB2_IPOD_AUDIO - DIGITAL/ANALOG/AUTO I have tried this on my NBT and it works. https://f30.bimmerpost.com/forums/sh...d.php?t=950010 Last edited by ezaircon4jc; 07-18-2018 at 01:49 PM.. |
07-19-2018, 12:20 AM | #11 |
Rep 9
I have coded this:
HU_NBT => API_IPOD_VIDEO = both HU_NBT => API_USB_VIDEO = both While it fixed the cable connection to the armrest usb and the iphone is now seen as USB device, I still have no connection via the snap-in. I can see the following now: USB1_IPOD_AUDIO digital USB2_IPOD_AUDIO auto I will try changing USB2 to digital, maybe that will solve the issue. Not sure if the following are related: API_APPLE_AUTH_CHIP_ON_OFF: aktiv API_IPOD_2WIRE_ON_OFF: nicht_aktiv APPLE_ENHANCEMENTS: nicht_aktiv |
07-19-2018, 01:19 AM | #12 |
Rep 9
Coded both USB1_IPOD_AUDIO and USB2_IPOD_AUDIO to digital - still no luck.
Coded APPLE_ENHANCEMENTS to aktiv - no effect whatsoever - reverted Coded API_APPLE_AUTH_CHIP_ON_OFF to nicht_aktiv - lost cable connectivity also - reverted Did not try API_IPOD_2WIRE_ON_OFF - does anybady know what that does? |
