2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
12-14-2021, 12:29 PM | #2509 |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
q
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
12-24-2021, 08:43 PM | #2510 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Picked up from tint shop, threw on snow tires and hit the car wash on the way home.
12-25-2021, 10:33 AM | #2511 |
Rep 2
Changed out the grills to black double slat. really made a difference.[IMG]undefined[/IMG]
jayster0966209.00 ferizzo84.00 |
12-25-2021, 04:54 PM | #2512 |
Rep 339
12-25-2021, 05:27 PM | #2513 |
Rep 12,565
35% all around but with the sunshades down it looks like 20% at times. During the day it’s more visible especially since I have a light interior.
Jeffcharger18.50 |
12-25-2021, 11:14 PM | #2514 |
Rep 339
Looks great! I was looking to do 20% since I don't have sunshades.
12-29-2021, 07:27 AM | #2515 |
Rep 118
Im having an issue, you might be able to help me. My jb4 plugs to the obd2 port and I have Bluetooth connection through my phone, but the app only shows boost and oil temp, the other gauges are dead.
01-01-2022, 09:51 PM | #2516 |
Rep 194
Just passed 100k miles so knocked out an oil change, trans service (third time), spark plugs, ignition coils, and a diff oil change. Has been a solid daily for the last 4yrs and 75k miles.
Tractor got fresh oil also Last edited by 88atlas07; 01-01-2022 at 10:02 PM.. |
jayster0966209.00 |
01-02-2022, 01:20 PM | #2517 | |
Rep 262
If it is a new install, is it a new or used unit?
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
01-02-2022, 01:22 PM | #2518 | ||
Rep 118
01-02-2022, 01:43 PM | #2519 | |||
Rep 262
I'll grab Terry's email and send you a PM now. He is very responsive and he would know exactly what your issue is. I have had JB4 for 3 years now and it's a excellent product, I have had almost zero issues with it, the only issues were on my end. I still use it everyday on top of my flash especially for my WMI control. So it's probably something simple to fix.
2011 550i (N63)
01-02-2022, 05:54 PM | #2520 |
Rep 221
Front splitter
Had a chance today to install my front splitter and I do like the change to the look of the front end. My little present to myself is put to good use.
Thanks to fellow member @spielnicht for the good deal. |
spielnicht439.50 SH0NWICK0.00 |
01-03-2022, 07:26 AM | #2521 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Looking great Glad it found a good home and instant use.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
jayster0966209.00 |
01-07-2022, 11:46 AM | #2523 |
Rep 951
Hey Bud! That g30 mirror looks really good! I tried the G30/G12 but the bracket seemed too long and positioned the mirror a bit further down on the windshield. Also the Mirror trim cover did not fit (I have the KAFAS camera).
I ended up retrofitting a g20 mirror and that fit much better (albeit not perfect and had to change out the connector but no biggie) |
01-07-2022, 12:07 PM | #2524 | |
Rep 1,356
01-07-2022, 01:32 PM | #2525 |
Rep 951
Good to know, and kudos to you for attempting the full disassembly route. I found it easier to swap to the G20 or G01 mirror as their base is smaller and you can almost fit the trim over them, but you have to swap out the connector (10pin to 6 pin). That is not difficult at all to do but you have to buy the connector and then of course use pick tool to remove pins and swap over. Overall, I definitely love the look of the new mirror as well as the fact that I don't have to press and hold the garage door opener button anymore, just press button once and let it do its thing. (bear in mind this is only applicable to folks with Post 2013 F10s as the mirror bracket that attaches to the windshield changed significantly
01-10-2022, 10:13 AM | #2528 | |
Rep 2,591
Kind of unfortunate that the EU homelink won't work with the NA homelink, as these mirrors seem to be dirt cheap in the EU salvage yard scene.
2015 BMW 535xi
01-10-2022, 08:17 PM | #2529 |
Rep 76
Put her on the lift to clean the undercarriage.
musclesmarinara75206.00 |
