2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
02-06-2022, 10:25 AM | #2553 |
Rep 4
02-06-2022, 02:05 PM | #2554 |
Rep 179
Drives: BMW 535i F10
Colored instrument cluster needles red. Turned out better than i expected. Now waiting for new steering wheel to arrive.
Does anyone know if its possible to remove the needles from the front? And how its done? Last edited by lukavergille; 02-08-2022 at 02:36 PM.. |
02-08-2022, 09:17 PM | #2555 |
Rep 9
Installed some sequential mirror markers. They match the other markers quiet well.
2014 535i Space Grey Metallic
09 328i Sedan(Daughters) (Totaled) Last edited by EastTexan; 02-13-2022 at 03:12 PM.. Reason: Added photos. |
02-19-2022, 11:40 PM | #2556 |
Rep 1,356
X7 frameless mirror retrofit and Euro frameless side mirrors
jayster0966209.00 marek55535.50 |
02-21-2022, 11:06 PM | #2557 |
Rep 262
Are you asking about removing the instrument needles?
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
02-22-2022, 06:48 PM | #2558 |
Rep 951
02-22-2022, 07:13 PM | #2559 |
Rep 1,356
02-22-2022, 07:19 PM | #2560 |
Rep 951
Naah man, I already have the g20 mirror.. can't justify switching just because frameless 🤣
02-22-2022, 10:12 PM | #2561 |
Rep 2,591
Euro side mirrors also aren't flat like american ones, so you reduce your blind spots by quite a bit
2015 BMW 535xi
02-26-2022, 04:54 PM | #2562 | |
Rep 179
02-28-2022, 03:04 AM | #2563 | ||
Rep 262
Yes about the instrument cluster needles, is it possible?[/QUOTE] Yes, they pop off fairly easy, actually just did mine today adjusting my needles from the last time I pulled them. There is a YouTube video but the quick steps are as followed. Using gloves, tape two spots with painters tape on each side of the needle to prevent scratching, use a spoon on each side of the needle on top of the tape and with equal gentle force pry the needle up. When you reinstall them, just zero out the dial and very gently turn it to the left, if it stays at 0 (or the lowest setting for fuel or oil temp) then firmly press the needle down until you feel it engage a second time. But if you can turn it past the 0 mark then move it as far as it will turn to the left and gently pull the needle out by hand and re-set it again at zero and then set it into place. The video online was someone installing a Venoxy faceplate on a 3 series but it works the same. It's very simple. Good luck.
2011 550i (N63)
lukavergille206.00 |
02-28-2022, 12:23 PM | #2564 |
Rep 5,388
03-03-2022, 10:04 AM | #2566 | |
Rep 2,591
2015 BMW 535xi
03-03-2022, 12:20 PM | #2567 |
Rep 179
Installed a new LCI steering wheel
musclesmarinara75206.00 550bye1391.00 |
03-03-2022, 02:07 PM | #2569 | |||
Rep 179
Yes, they pop off fairly easy, actually just did mine today adjusting my needles from the last time I pulled them. There is a YouTube video but the quick steps are as followed. Using gloves, tape two spots with painters tape on each side of the needle to prevent scratching, use a spoon on each side of the needle on top of the tape and with equal gentle force pry the needle up. When you reinstall them, just zero out the dial and very gently turn it to the left, if it stays at 0 (or the lowest setting for fuel or oil temp) then firmly press the needle down until you feel it engage a second time. But if you can turn it past the 0 mark then move it as far as it will turn to the left and gently pull the needle out by hand and re-set it again at zero and then set it into place. The video online was someone installing a Venoxy faceplate on a 3 series but it works the same. It's very simple. Good luck.[/QUOTE] Thank you for this much detail man, appreciate it |
03-03-2022, 02:08 PM | #2570 |
Rep 179
03-03-2022, 08:33 PM | #2571 |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
I like this wheel combo witht he CF.. I was going to go that way, but went with basically all alcantara except for the sides on the stock wheel... what did that set you back??
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
03-04-2022, 05:36 AM | #2572 | |
Rep 179
I was also thinking to go full alcantara with round steering wheel but something told me to go extra… |
03-04-2022, 11:44 AM | #2573 |
Rep 505
You made the right choice!! it looks really good!!.. enjoy it man!
03-04-2022, 12:39 PM | #2574 |
Rep 179
Appreciate it man, thanks!
