03-13-2020, 12:57 PM | #1 |
Rep 10
n55 OFHG
I keep reading horror stories about n55 engines seizing with failed rod bearings after OFHG changes. Has anyone experienced this? Mine isn't leaking currently, but I know its only a matter of time.
03-13-2020, 01:34 PM | #2 |
Rep 658
LMAO! Man stop reading car stories from those flat-earth websites jk
What WILL kill rod bearings and seize engines is running them out of oil (like if you have a leak and don't take care of it). Or, if you did the OFHG and you didn't properly torque down the bolts... you'll end up with a leak... which if you don't notice in time can cause you your engine. So in short, no. Changing gaskets doesn't lead to seized engines or killing rod bearings. What DOES cause them is having leaky gaskets and not monitoring your oil level allowing it to starve. Hope that answers your question!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
03-17-2020, 12:55 PM | #3 | |
Rep 470
The issue with N55 OFHG and siezing engines is apparently related to the external oil cooler. The basic heat exchanger shouldn't have this problem since it is all attached to the oil filter housing and doesn't pipe down/back up from a radiator in the bumper... Anyways, the problem comes down to the oil pump not being able to clear air bubbles in the oil cooler, resulting in starvation. Procedure from BMW is to prime the oil system for 30 seconds (with ignition or fueling disconnected) before starting. BUT! Even with that procedure followed to a tee, people have lost engines to this. I have heard it is related to the idle oil pump speed and that immediately getting in and driving will bring revs up enough to deal with the air pocket in the oil cooler before serious damage occurs. Most of the time this issue immediately shows up (within 300 miles). I haven't seen many N55's with this issue once they get higher than that. I have also heard that people are waiting too long to do the job, leading to dirt/gunk dropping down oil galleys. This is less common and obviously an install issue, but it has happened. N55: https://www.1addicts.com/forums/show....php?t=1537202 N55: https://www.reddit.com/r/Justrolledi...ilter_housing/ N55: https://bmw.*********** .com/threads/broken-n55-crankshaft.4716/ < sp00lstreet but we still have censorship N54: https://www.n54tech.com/forums/showt...t=57495&page=2 This is very common people.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
03-17-2020, 01:37 PM | #4 |
Rep 658
WOOOOOW I guess I have been dude I've never heard of this! But thank you for sharing and explaining it in detail for us under-rock residents lolol!
doodlebro121.00 |
03-17-2020, 01:40 PM | #5 |
Rep 1,299
I second that information... My BMW mechanic told me this is true story and they had this happen to cars with as low as 30k miles. I have external oil cooler and my OFHG was replaced 50k miles ago. So whoever did the job did it good.
03-17-2020, 04:34 PM | #6 |
Rep 1,442
Drives: 2011 535i 6MT
WOW i just did my OFHG but everything is fine... Is it only when you do the pan too? How is the oil bubble introduced to the pump? Wouldn't a normal oil change do this too?
03-17-2020, 04:41 PM | #7 |
Rep 470
The bubble is not in the pump, is in the oil cooler which breaks off of the OFHG on the cars that have it.
Current mods
03-17-2020, 04:41 PM | #8 |
Rep 1,299
03-18-2020, 08:34 AM | #9 | |
Rep 1,873
My problem with the recommendation is this: If the problem is insufficient oil pump speed and pressure during idle - why is the speed and pressure SUFFICIENT at starter speed? That just doesn't make sense. If the issue was loss of prime - sure. If the issue is oil cooler air bubble, cranking on the starter isn't going to help. The N55 has an electronically controlled variable-displacement oil pump. I've seen no indication in my documentation that extra volume/pressure is called for during start that is not called for during idle. Because of the high amount of electronic control, I would expect a specific ISTA+ oil priming procedure. Time to do some more research. I'd also love some iron clad information that if you don't have the external oil/air cooler you aren't at risk (since I don't have one ) |
03-18-2020, 08:36 AM | #10 |
Rep 1,442
So do I need to be nervous each time I change my oil? Think of how many N55's with oil coolers are out there and get their oil changed constantly... this has to be some sort of weird anomaly.
03-18-2020, 08:47 AM | #11 |
Rep 2,590
I don't think oil changes touch the oil in the cooler. After all, you'd have to undo the hoses to drain that oil since it sits at the filter area, way higher up than the cooler. So in theory it shouldn't cause an issue.
2015 BMW 535xi
Shrimpy22.50 |
03-18-2020, 08:49 AM | #12 |
Rep 1,442
Anyone have a pic/image of where the pump is that get's the air bubble?
03-18-2020, 09:00 AM | #13 |
Rep 14,522
we just did mine yesterday since we changed the oil filter housing gasket and oil cooler gasket. Burrninja and i performed this by priming the oil system for 30 seconds (with ignition or fueling disconnected) before starting. there's 3 fuses we had to pull in the trunk. from there he than had the coolant capped removed to where you can see it spitting into the reservoir where he would keep adding blue coolant until it stopped.
03-18-2020, 10:42 AM | #14 |
Rep 538
Picture of the fuses to pull? For future reference for all of us when priming the system.
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
03-18-2020, 11:15 AM | #15 |
Rep 14,522
i'll take some pictures when i get off work today. there's a diagram that's stored next to your fuses but it's the fuel logo i believe and it has 3 fuses #'s next to it. 134(5), 135(5) and 189(20)? i'll confirm this like i said when i get home. this prevents the car from starting so it allows the priming of the oil system
03-18-2020, 11:37 AM | #16 |
Rep 2,590
Pretty sure there's no dedicated pump for the oil cooler. It's the same oil pump that is used for the rest of the oil system.
2015 BMW 535xi
Shrimpy22.50 |
03-18-2020, 12:54 PM | #17 |
Rep 1,299
The mechanic that works on my car said he seen and experienced n55 engine seizing after oil changes.
03-18-2020, 02:31 PM | #18 |
Rep 2,590
You sure he's specifically talking about the ones with the oil cooler?
2015 BMW 535xi
03-18-2020, 02:40 PM | #19 |
Rep 517
I think there's a YouTube or maybe FCP video that shows refilling through the OFHG
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
03-18-2020, 03:49 PM | #20 |
Rep 1,299
No he never mentioned oil cooler. He just said they had few n55 that came in for oil change and they end up seizing the engine after oil change. He did say it was caused due to air bubbles in the pump/line I don't remember that part.
03-19-2020, 07:15 AM | #21 |
Rep 14,522
that's what we did. we filled the oil in the OFHG, added some oil to the inside of the filtration than added the rest in the normal oil refill cap
03-19-2020, 07:16 AM | #22 |
Rep 14,522
is this the same Bmwdoubles?? your post count is off
