2010 2011 BMW 5 Series Forum F10 2014 F10 - RPM Drop on Cold Start |
08-30-2020, 01:29 PM | #23 |
Rep 658
are you guys (burr and Willy) on the original coils?
I think it was burr that said you started getting this at 83k and still now. At that 83k N55s don't have THAT much CBU to merit that cold-start behavior (if it was an N54 I'd say heck that's your problem right there LOL). I had a shaky idle and cold start ever since I started modding right after i bought the car at 109k. It got worse as we got into the summer heat. Felt like a misfire but I had no codes. I changed the plugs to N20 NGKs (FCP!) gapped down- it got better but still noticeable. I bit the bullet and got a set of Eldor coils (FCP again!) and BUTTER SMOOTH. Not a single twitch in cold start or idle (cold or heatsoaked). Rock steady.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
08-30-2020, 01:30 PM | #24 |
Rep 658
This is a good point too! And it's not too hard to pull these and clean them out. Put new gaskets and back in they go.
09-01-2020, 06:33 PM | #25 |
Rep 85
Thanks for this, started the car today after sitting for a few days and the RPM dropped to around 600, so I guess the intake is not the issue. Will talk to my mechanic about the solenoids. Thx.
2015 650i F12
2014 535 F10 2011 335i E93 Sport (Blown Engine - Sold) |
09-01-2020, 06:55 PM | #26 | |
Rep 915
Instgram @burninja
11-06-2020, 09:12 AM | #27 |
Rep 85
As the colder weather has come on, the cold start issue has now moved on to rough running for about the first 10 minutes until warm. Not really rough, but enough that it feels like the tires are out of balance. Going to do the VANOS solenoids next week, will report back.
2015 650i F12
01-13-2021, 02:44 PM | #28 | |
Rep 547
01-18-2021, 09:33 PM | #29 |
Rep 118
I have had the same issue for a few years by now on my n55. Did everything go the car, spark plugs, both fuel pumps, vanos solenoids, maf/map sensors, fuel filter, injectors, solenoids, valve cover and gasket, and I'm sure I'm forgetting some other things. I could never got rid of the cold start issue. It did get better in the sense that rpms don't dip lower than 1000 now, but still bounces on cold start. I have prob invested a good 6 to 8k on trying to make the car start right, to no avail. Only think left to try is walnut blasting.
02-06-2021, 02:48 PM | #31 | |
Rep 85
2015 650i F12
02-09-2021, 09:19 AM | #32 | ||
Rep 118
02-09-2021, 09:28 AM | #33 |
Rep 193
Forgot where I read this but someone posted that it could be a vacuum leak. Not sure exactly from where. I have a 550i btw. Mine does the same thing. When the engine is not at operating temp, the idle is at 750. Once the engine is warm Rpms drop to 500ish and go up to 750 if the a/c is on.
02-09-2021, 07:39 PM | #34 | |
Rep 118
02-10-2021, 08:12 PM | #35 | |
Rep 85
Thanks for this info, those sensors don't seem to be too expensive, I'll give that a try and see what happens, we've already replaced the vanos solenoids and it's getting an oil change tomorrow. Will report back, once this is done. Thx.
2015 650i F12
02-12-2021, 11:13 PM | #36 | |
Rep 1
02-15-2021, 10:35 AM | #37 |
Rep 85
No, I'm not shifting right away, usually wait about 30 seconds before I go anywhere. Replacing the cam shaft sensor this week to see if that helps. Will let you all know how that goes.
2015 650i F12
02-15-2021, 09:48 PM | #38 | |
Rep 118
02-16-2021, 03:43 PM | #39 | |
Rep 118
02-16-2021, 05:52 PM | #40 |
Rep 85
They do have their quirks, but I have to say, when I'm cruising down the highway, all is forgiven. I just love everything else about these cars and will suffer through the odd issue that drives me nuts. Also, just picked up a 2015 650i xDrive convertible, looking forward to enjoying that once the snow melts.
2015 650i F12
02-16-2021, 07:02 PM | #41 | |
Rep 118
03-13-2021, 11:30 AM | #42 |
Rep 85
March Update
So we just replaced the cam sensor and the spark plugs. 3 of the plugs were a nice tan color as expected, however, 3 were boot polish black, obviously running rich on those 3 cylinders. Could be injector issues, but we're trying some injector cleaner through the gas tank first. Will run seafoam for the next few tanks and see what happens. However, the new plugs did make it better, so fingers crossed for the injector cleaner. Will update again in a few weeks. We'll also pull the plugs at the next oil change and have a look see.
2015 650i F12
03-13-2021, 12:59 PM | #43 | |
Rep 118
03-15-2021, 01:09 PM | #44 |
Rep 85
Thanks, I've already looked on ecs site. But this morning, she barely dipped below 1,000 rpm, so it is definitely getting better. ½ a tank to go, then fill up again with seafoam. Also, went for a drive yesterday using manual mode and kept it above 3,000 rpm on the highway for a while.
2015 650i F12
