2010 2011 BMW 5 Series Forum F10 Oil coming out of intake tube? |
10-24-2020, 08:19 PM | #1 |
Rep 13
I have a 2016 535i and upon removing the intake to get to the spark plugs I noticed oil coming out of a tube into the intake. The tube comes from the PCV valve area and goes into air intake tube. Is that normal? It's running really great so took me by surprise. Attached is a picture.
Also do my old sparks look ok even tho they have white on them? I heard this could mean it's running lean? 52k miles on them from factory. |
10-24-2020, 10:43 PM | #3 |
Rep 913
To much oil passing through no. Failing PCV system can cause excess oil, you can reduce this replacing valve cover and using a catch can to contain it from going into intercooler and beyond in future. The catch can will not catch a lot with replacement valve cover with good pcv. Inside the pcv is a diaphram that can wear out which is the circle piece in the center of the valve cover.
Instgram @burninja
OnlyGerman362.00 |
10-24-2020, 10:59 PM | #4 | |
Rep 13
10-25-2020, 04:26 AM | #5 | ||
Rep 913
https://www.turnermotorsport.com/BMW...reather-system
Instgram @burninja
10-25-2020, 07:24 AM | #6 | |||
Rep 13
BurrNinja427.50 |
10-25-2020, 09:14 AM | #7 |
Rep 913
Anytime! Thats what I'm here for to help others with things I've learned. I may not explain things to the best of way but I try. Hope the best for you in a solution.
Instgram @burninja
OnlyGerman362.00 |
10-25-2020, 08:33 PM | #8 |
Rep 79
A couple of us had similar issues with excessive oil back to the intake. When I changed the valve cover and I flipped the old one around, there was like a half liter of oil pouring out, I felt like something is stuck and oil isn't going back down. I didn't have any PCV issue but a gasket leak.
Oil catch can is certainly a good way to reduce the gunk but I think the issue originates from the value cover, it's not a great design only bc it's expensive to replace. |
BurrNinja427.50 |
10-25-2020, 09:07 PM | #9 | |
Rep 13
10-26-2020, 12:19 PM | #10 |
Rep 1,442
Drives: 2011 535i 6MT
Does your car only have 52k miles on them? This is blow by... wouldn't think you'd have that much if you only have 52k miles.
OnlyGerman362.00 |
11-04-2020, 09:05 AM | #11 |
Rep 4,632
Just a FYI, the breather tube aka heating element, should be removed via 2 screws on the intake pipe, and not removed via the clips on the valve cover.
This is highlighted as a warning in ISTA
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
11-04-2020, 10:41 AM | #12 |
Rep 538
This is normal. I had something similar, but a bit less in the pipe, when i did my plugs a couple months ago at 69k on my 2016. Just cleaned it up and good to go.
Your plugs do appear a bit more fouled up than mine were though.
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
