2010 2011 BMW 5 Series Forum F10 How much would an indy shop charge for an oil pan gasket replacement on a F10 535ix? |
03-19-2023, 05:56 PM | #1 |
Rep 175
My 2013 535ix has an oil leak from the oil pan that has progressed to drips on the floor. I watched this video of the repair and didn't realize how extensive it is due to the front axle going through the oil pan.
Has anyone paid to have this gasket replaced at an independent shop? How much did they charge? Last edited by 2013F10; 04-23-2023 at 02:16 PM.. |
03-20-2023, 05:23 PM | #3 |
Rep 462
Yes - it is that much work. I don’t think the power steering rack needs to be unbolted but nonetheless that process is right.
The question is, since labor is so expensive what parts would you change in the process to save in the long run: Trans oil pan Front diff oil Transfer case oil Suspension arms? Replace engine mounts Etc. 10yr old bmw will need some parts replace and the labor should be somewhat included in the job. Below is the bmw pre-work for the oil pan: Necessary preliminary tasks: Remove left charge air duct. Drain and add engine oil. Remove front axle differential. Remove bearing support. Detach power steering pump and set it aside (Dynamic Drive only). Remove engine support arm. Detach deflecting element and holder from oil sump. |
04-23-2023, 02:19 PM | #4 | |
Rep 175
