2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums CANADA Rim Fitment
      10-16-2019, 11:36 AM   #1
Kassav
Drives: 2011 535i X-drive
Rim Fitment
Hey guys,
I'd like to purchase a set of 5- 18-inch OEM rims off a 2003 750Li owner who's over 600km away. Being unable to try the rim prior to purchase I'm hoping someone can let me know whether these will fit on a 2011 535i X-drive.
They both have the same bolt pattern: 5x120mm. Id greatly appreciate you assistance.
Thanks in advance
      10-24-2019, 09:42 AM   #2
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Originally Posted by Kassav View Post
Hey guys,
Thanks in advance
Ask the current owner of the rims about the width and offset for them, and if he can, the hub bore. Failing that, can you post a picture or otherwise point us to the wheel you are talking about?
One more option for you, if you wish to do your own research, is to check out this link here, which gives you the specifications for wheels of all models of BMWs. Check to make sure the hub bore works, and then compare the wheel width and offset. I did a quick check for a 2003 7 Series, and while I could not find a 750Li, I did find a 745Li and 760Li model, and the bore matched the F10. Offset and width would also work but the wheel would poke a bit more outwards than stock for an F10. The 2013 750Li specs were closer to what we have on the F10 and would definitely work.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      11-30-2019, 10:38 AM   #3
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Did you sort this out?
