07-07-2020, 11:20 AM | #45 | |
Rep 517
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
07-07-2020, 06:42 PM | #46 |
Rep 517
Updates:
After speaking with a few wise BMW peeps. The problem maybe a couple of things. 1. SMF and spec 2 clutch caused a crankshaft error. 2. Helix Overdrive is beginning to bind and oil seepage is happening causing time chain slippage. 3. All of the above. In either case, MHD didn't cause corruption to my ECU as they mentioned when I contacted them "it was purely coincidental". The Helix one is killing me.
07-07-2020, 06:52 PM | #47 | |
Rep 716
07-08-2020, 06:44 PM | #49 |
Rep 517
Got the ecu to take a stock flash. The fuel module is not taking a flash reset so replacing that. Right now the car starts but dies after a few moments because of the ekpm. After replacing that fuel module we'll see about this potential Helix issue.
07-08-2020, 08:01 PM | #50 |
Rep 1,299
So Helix overheated the fuel module? I wish there was a way to install the new style hpfp instead of this Helix which seems to have caused more problems than anything from what I hear. Even the guy I know with 335i is having bunch of issues related to or because of Helix.
07-08-2020, 08:23 PM | #51 | |
Rep 517
The helix is suspect right now so it's unconfirmed. The assumption is the Helix OD is binding causing timing chain slippage. This would cause the crankshaft sensor to not be synchronized. The crankshaft sensor is only used on start. Which then points to the aftermarket SMF and clutch potential throwing off the Crankshaft sensor. It's all unknown at this point. I'll have more info day by day.
07-10-2020, 02:42 PM | #52 |
Rep 517
The dealer was able to flash the ecu back to an operational state however the crankshaft sensor is still there. Part of my problems were due to EKPS which is now replaced and fine. The error code for the crankshaft sensor remains even after all of that, but the car starts and runs without dying. Going to replace the CS sensor and see if the error continues.
07-10-2020, 05:16 PM | #53 | |
Rep 716
Bmwdoubles_194.00 |
07-10-2020, 05:47 PM | #54 |
Rep 1,442
Drives: 2011 535i 6MT
Good news! So the Fuel pump control? Any idea why that went out?
07-11-2020, 07:22 AM | #55 | |
Rep 517
When I get it back I'm very nervous about flashing it again. I'm ordering the WiFi MHD adapter to speed up flash times. I'll be sure to click in the seat belt during the flash. I think part of my problem was the car did go to sleep during the that 24 minute flash back to stock time. The crankshaft error was coincidental. I think lol. I'm replacing the CS sensor, flywheel and clutch so we'll see.
07-11-2020, 12:35 PM | #56 | |
Rep 1,873
All of the flash tuners take advantage of exploits in the code in the ECU - same as rooting or jailbreaking your phone or game console, and usually a bad thing on your PC or Mac, but necessary for BM3, MHD and similar. BMW "fixed" it a while back. I'll post more specifics if I can find them again. |
07-11-2020, 12:54 PM | #57 | ||
Rep 517
07-12-2020, 07:55 AM | #58 | |
Rep 1,230
yes bro. More power being added puts more strain on the ekpm3. I was fine for years with the stock one. Even on custom tunes. Not till i started tuning for e50+ thst ekpm3 problem happened to me on the dyno. At that point i was clueless cause the car would shut off repeatedly. Then after a couple weeks would get worse. Its all on how much strain you put on the fuel system
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
Bmwdoubles_194.00 |
