08-13-2018, 01:30 PM | #1 |
Rep 5
Drives: '16 BMW 535i & '16 328i GT
New member and question
Hello All,
New member here with a question. I have just bought a 2016 535i with 22k miles. Just underneath the driver's side button that controls the temperature on the HVAC there's a small button. It doesn't push in when pressed and nothing happens on the system (that I notice). The button is there on the 5 series, the 3 series, and it's on a 2018 X2 "loaner" I'm driving while my car is in the shop. I asked the service guy if he knew, and he didn't. So not being satisfied , I sought out the shop foreman with my question. He came over to my car, sat down, pushed the button a few times and said, "no, I don't know, never noticed it". I asked if it had something to do with "disassembly" if the unit was out of the car and he just shrugged his shoulders and walked away. Not that I'm going to lose sleep over it, but does anyone know what's it for? Thanks for your thoughts. |
08-13-2018, 02:21 PM | #2 |
Rep 4,046
That round dot like thing? Its a light sensor or something. Dont break it
08-13-2018, 07:24 PM | #3 |
Rep 14,522
That's the Flux Capacitor! It's what makes time travel possible
sonus47.50 woodnook12312.00 |
08-14-2018, 03:55 PM | #4 |
Rep 659
That is the camera so big brother can watch!
Sorry, please refer to BigKutta answer. |
EL Jeffe 5611.50 sonus47.50 |
08-20-2018, 07:08 AM | #6 |
Rep 5
Thanks guys for taking time to reply. I enjoyed your responses. I was also told on another forum that it's a cabin temp sensor, close to what BigKutta was suggesting. Best to leave it alone, huh? Thanks again guys. As for posting pics, I can't because the dealer has had the car for the past two weeks.
tet0010.00 |
09-07-2018, 08:21 PM | #7 |
Rep 5
For some unexplained reason, I keep coming back to this thread to see if there are any replies. So far, Isturbointeg has the most comical and (possibly) most intriguing answer. Come on guys, "take the challenge". BTW, United BMW of Roswell, GA, did a great job on my car with another (and totally unrelated) issue regarding 'bad' front struts from the factory. Two weeks to get new struts, but now "perfect". The car rides and drives GREAT. I've got a 2 year old car with 23K miles and a brand new front end. WONDERFUL
lsturbointeg9151.00 |
09-13-2018, 12:16 AM | #8 |
Rep 361
That same black dot on Chrysler/Jeep vehicles is a laser that reads skin surface temperature and adjusts the climate control accordingly in conjunction with the sun load sensor and in vehicle temp sensor to make sure that the system doesn't blast you or under performs if your surface temp is or isn't inline with the climate controls pre-determined values.
ChryCo got this tech from their years with MB and I wouldn't be surprised if it performs the same function on BMW models. It's old news actually...kinda 04-05 ish if my memory serves me right. My moms 05 AWD Hemi 300C has it and it performs especially well on a hot day hopping in the car after you've been swimming when the skin is at different temps than the climate system agrees with.
Janet Jackson Unbreakable World Tour
08-10-2019, 04:55 AM | #9 |
Rep 1
Using knobs to control the temperate
I could do with a little help. I have just brought a 525d 2009 and am having problems with the climate control. I know how the change it thought the iDrive but ideally I’d like to change the temperature using the two knobs either side of the knob that controls the fan speed. Any advice is really appreciated.
08-10-2019, 09:57 AM | #11 | |
Rep 14,522
08-10-2019, 02:27 PM | #12 |
Rep 5,332
On the subject, does anyone know just where the interior sensor is physically located? I've been all over newtis and it just explains function, not actual sensor location (that I can find).
TIA |
08-11-2019, 11:56 AM | #15 |
Rep 659
Deeper inside, my understanding it is before that side splits to center and outside.
What I read was saying it was easier to get to from the wheel skirt. |
08-11-2019, 12:42 PM | #16 |
Rep 7,449
KoP was correct...its a temp sensor. The answer to the original question is...the "dot" (little black button) is the temp sensor for regulating the IHKA. In the past, there used to be a "forced air" set-up...so there was a grid (#17 in the 1st pic below) where air was drawn into the IHKA across a thermistor or other sensor which helped the IHKA control panel maintain the set temperature. But from July/2012 BMW changed to the little "dot/button" thingy. This change also reduced some of the common issues with the forced air induction set-up...which was the accumulation of dust on the little fan blades (inside the IHKA) as well as the noise that occurred as the interior fan became imbalanced due to the dust build up.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-11-2019 at 01:05 PM.. |
Kyngofpop676.00 |
08-11-2019, 04:48 PM | #17 | |
Rep 5,332
They also replaced the high pressure fuel pump (P/N 13 51 8 604 231) per a TSE. |
08-25-2019, 03:35 PM | #18 | ||
Rep 361
