2010 2011 BMW 5 Series Forum F10 rotors and pads share your experience... |
11-13-2018, 12:28 PM | #1 |
Rep 1,154
Anyone care to share your experience on replacing your oem rotors/pads...
have you gone aftermarket? stuck with oem? Why did you go aftermarket? strictly cost? performance? my rear pads are up for replacement and am trying to figure out the best route to go. my main concern is performance, which includes not only braking performance, but also NO chattering/squeaking when braking... I don't track the car so don't need anything high end...just something as good as oem if not slightly better... just seeing what others have done... Thanks! |
11-13-2018, 02:54 PM | #2 |
Rep 4,048
I was getting a very strong front end vibration when on the OEM rotors and pads. When it was time to change, went with Akebono rotors and pads and no more vibration. But the damn brake dust is back...
11-13-2018, 03:10 PM | #3 |
Rep 590
Do you change your sensors after every brake pads replacement ?
11-13-2018, 06:16 PM | #5 |
Rep 590
11-14-2018, 09:05 AM | #6 |
Rep 4,048
11-14-2018, 10:22 AM | #8 |
Rep 4,209
I went with OEM pads that came with the senor from the local auto part store. The rotors were actually good enough to get resurfaced so did that. Didn't take too long:
https://f10.5post.com/forums/showpos...&postcount=244 You'll need a torque wrench, regular wrench with a variety of sockets, brake cleaner, screwdriver, hammer and jacks. |
11-14-2018, 11:24 AM | #10 | |
Rep 1,254
torque everything to spec Flush fluid and buy EOM pads, rotors. in my life time all the brake jobs I did on many different cars and Motorcycles. Its all commonsense don't over tighten or don't just finger tighten. I can tell you I never used Torque wrench, EOM pads or rotors I did replace one of the sensors back in 2005 on my 2002 323i it got damaged. thanks God Bless
Kyngofpop676.00 |
11-14-2018, 11:28 AM | #11 |
Rep 77
I used Zimmerman Rotors Coat-Z and OEM Pads for the Front. I had to replaced front rotors as they had too much groove but doing it at 100k on original is just great. I like is so far. I did replace the sensor even though it was in very good condition.
I used OEM Pads for the Rear but left original rotors, as they were in very good condition at 60k. I did replace the sensor even though it was in very good condition. I will be using Zimmerman Rotors, Coat-Z when time comes to replace rotors on the next brake job, at around 120k or so.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
EL Jeffe 5611.50 |
11-14-2018, 12:05 PM | #12 |
Rep 7,480
If you didn't get the brake pad warning...then the sensor is still "intact". Yes, you could change it, but if you are changing your brake pads BEFORE the warning appeared...then you'd be throwing away a perfectly intact brake pad sensor that can still be used.
And if you did reuse it because you replaced your brake pads prior to receiving the warning...there will be enough material on the new brake pads for thousands of more miles before the pad get's thin enough again to start wearing down to where the sensor would make contact and wear down to trigger the warning. Just a thought.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Kyngofpop676.00 EL Jeffe 5611.50 |
11-14-2018, 04:51 PM | #13 | |
Rep 361
Janet Jackson Unbreakable World Tour
EL Jeffe 5611.50 |
11-16-2018, 12:37 AM | #14 |
Rep 74
Get your brakes from FCP Euro https://www.fcpeuro.com . They have LIFETIME replacement on everything they sell even wear and tear. They have oem and zimmerman brakes.
Kyngofpop676.00 |
11-16-2018, 11:22 AM | #15 | |
Rep 1,154
11-16-2018, 06:33 PM | #16 |
Rep 74
it does sound too good to be true, but its true haha.
https://www.fcpeuro.com/page/lifetime-guarantee |
Kyngofpop676.00 |
11-20-2018, 10:41 AM | #18 |
Rep 7
I also researched FCP's return policy. They will even take back used oil & filter if you bought it from them. They have a video on how to pack it to ship back.
What I don't know is how much it would cost to ship oil & filter back. May make it a waste of time |
Kyngofpop676.00 |
11-20-2018, 12:09 PM | #19 |
Rep 639
As for pads, I’ve used Akebono on a previous BMW (2006 325i) and just recently changed to Akebono on my current f10. Previously I noticed much less dust and they seemed like decent pads for spirited street driving. Time will tell with the change in the current vehicle. I’ve also never replaced wear sensor, always reused old ones if undamaged.
11-20-2018, 12:51 PM | #20 | |
Rep 595
The initial bite they offer is superb. Tap the brake a little and they grab with immediacy and authority. Most aftermarket pads have a hard time retaining all of the initial bite of the OEM bmw pads. Aftermarket pads may offer: Less dust Linear feel Less Fade Longer Pad life Increased Rotor Life But beware any aftermarket pad that says they have initial bite equal to the OEM pads. Most simply just DO NOT. This includes some of the popular pads from HAwk, Ebc, Powerstop, Stoptech, etc. The Textar ePads do not bite as well either. Some people don’t like the “grabby” OEM pad feel. Aftermarket pads will dull this quite effectively. But if you value the traditional BMW, ultra responsive pedal feel and response you will be best served by OEM pads. Also note that BMW pads on one axle and aftermarket pads on the other (front/rear) will change your brake bias too. And that bias, will again vary, as the pad temperatures change. Again, some may not notice, but it’s there. Your profile says you have a 550i... To get OEM BMW performance, get OEM pads. If you want an upgraded pad, you can order M5 rear brake pads for a bit more bite and fade resistance, but with more dust. The M5 rear pads are a direct fit for the 550i rear. No other parts are needed. Here, be mindful that M5 front pads don’t fit (without other parts), so you will have stock fronts and M5 rears. This will increase rear bias a bit. I mention the bias because the DSC, ELSD, Traction Control, and Corner Brake Control systems all “expect” and are calibrated for a pad of stock characteristics. Changing the pads slightly effects these systems. I thought I could live with aftermarket pads, to get less brake dust. But the reduction in pedal response and initial bite, muted the brakes to an unBMW like state in my opinion. Now I use stock pads, but would love to have an aftermarket pad with OEM bite with the benefits of a high performance pad. One more thing, if the replacement pad you are looking at is a Ceramic pad, it will almost definitely have a more muted brake feel and response compared to OEM. I hope this info helps you select a good pad for your particular needs. |
11-21-2018, 04:45 PM | #22 |
Rep 1,154
ended up sticking up to OEM pads/rotors for my rear brakes...(fronts are still good)
i've used aftermarket pads in my last bmw and always had minimal brake dust but increased noise and less initial bite...thanks for everyone's input. |
