2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
11-13-2023, 10:12 PM | #3015 |
Rep 21
Did a wheel stud conversion. Should’ve done this mod earlier.
11-13-2023, 11:25 PM | #3016 |
Rep 2,995
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Did the Euro light switch upgrade to get rear fogs... sooooo easy, much easier than an E90! If you haven't done it, whatcha' waiting for???
11-14-2023, 12:10 AM | #3017 |
Rep 72
Drives: 2015 BMW 535i xDrive M sport
HI_F1064.00 ChiltiCoatl891769.00 |
11-14-2023, 12:11 AM | #3018 |
Rep 72
StradaRedlands4940.50 |
11-14-2023, 07:56 AM | #3019 |
Rep 251
11-14-2023, 08:10 AM | #3020 |
German Car Caregiver
32
Rep 28
Drives: 2014 BMW 535i M-Sport
Nice! I did the rear fogs on my E90's back when I still had them, and I intend to on my F10 soon. Glad to hear it's still as easy as it was back then. Quick question, does the headlight leveling dial do anything on the US cars?
2014 BMW F10 535i - Glacier Silver, Black Dakota; M-Sport Line, M-Sport Susp 704, Sport 8AT, Comfort Seats, Prem, HUD, PDC, Adaptive LED's, CA, Alarm, Soft-Close, Ceramic Controls, Style 351M
2011 BMW E90 328i - Space Grey, Saddle Dakota; Prem, Nav, Style 285 - Sold 2012 BMW E92 328i xDrive - Jet Black, Black Dakota; Prem, CA, Alarm, Style 338 - Totalled |
11-14-2023, 08:35 AM | #3021 | |
Rep 2,995
The leveling dial doesn't do anything, just sitting there looking pretty. |
11-14-2023, 11:06 AM | #3022 |
Coal Troll
150
Rep 326
I cleaned my new summer wheels for the 535d
275/35/19 (Ecsta ps71) ready to go on them too QUITE a bit early, but meh I was excited.
My hybrid burns Diesel & Oil
deleted F10 535d |
11-15-2023, 06:21 AM | #3023 |
Rep 639
Between the last two days I’ve conquered a brake fluid flush, oil change, transmission fluid and pan replacement, and swapped from my H&R sway bars back to stock.
11-15-2023, 12:09 PM | #3024 |
Rep 2,349
Why did you swap the sway bars back to stock?
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
11-15-2023, 01:32 PM | #3025 |
Rep 639
I got tired of the extra roughness over rough roads around town and speed bumps/entrances to driveways.
For the past few years I traveled mostly up and down the east coast of the US, but now work has me staying within Florida. Long distance highway travel wasn’t bad, it’s really noticeable around town though. |
StradaRedlands4940.50 ChiltiCoatl891769.00 |
11-15-2023, 04:16 PM | #3026 | |
Rep 2,995
How was the the trans pan/fluid job? I've been putting that one off. |
11-15-2023, 06:43 PM | #3027 | |
Rep 127
Regards, https://www.ecstuning.com/b-genuine-...316803965~geb/ Last edited by Conserve; 11-15-2023 at 06:45 PM.. Reason: . |
11-15-2023, 06:50 PM | #3028 |
Rep 127
Replaced coolant again to get mixing ratio up to 60/40. Preparing for winter in Ohio Lol.
StradaRedlands4940.50 Carbon535i351.50 |
11-15-2023, 08:41 PM | #3029 | |
Rep 639
You also need to have a good transfer pump to get the new fluid in and a way to read the transmission temperature. Some scanners do it, but ISTA makes the process super simple. Just follow the directions and click through to the next step until you’re done. The biggest thing is to be sure to go through the gears and do the final fill at the proper temperature with the engine idling. FCP has a good set of instructions online and a YouTube video I believe. |
11-15-2023, 09:30 PM | #3030 | |
Rep 2,995
11-15-2023, 10:20 PM | #3031 |
Rep 639
Prepare the best you can and make sure to take your time. Be sure to have a quality low range torque wrench. I believe the torque was 10Nm on the pan bolts. (New style bolts are steel, old style was aluminum and only 4Nm + 45 degrees I believe)
11-16-2023, 07:38 AM | #3032 | |
Rep 251
11-16-2023, 09:10 AM | #3033 |
Rep 2,591
Technically hitting a pot hole also makes you body roll. Any transfer of weight from side to side involves the sway bar.
2015 BMW 535xi
Double Nickel165.00 ChiltiCoatl891769.00 |
11-17-2023, 11:21 AM | #3034 | |
Rep 639
I also did replace all the front and rear suspension components around 30,000 miles ago and it didn’t make a difference in the perceived roughness that the sway bars caused. I’m very happy driving around town now that I’ve swapped back to stock. |
Double Nickel165.00 |
11-17-2023, 11:22 AM | #3035 |
Rep 639
11-17-2023, 05:14 PM | #3036 | |
Rep 251
