01-02-2016, 11:32 PM | #23 | ||
Rep 263
2007 Lexus ES350
2007 Lexus RX350 2005 Lexus ES330 1972 Mercedes Benz 280 SEL 2014 BMW 550i |
01-03-2016, 08:04 PM | #24 |
Rep 25
01-03-2016, 09:28 PM | #25 | |
Rep 263
2007 Lexus ES350
01-04-2016, 01:54 AM | #26 | |
Rep 25
Sorry to hear that. At least you know now how spring tab looks like, it will take one minute next time :-) http://www.getbmwparts.com www.fcpeuro.com Around $74 each. Many times, I got it directly from BMW dealer. Cheaper than online. Need to call them and tell them the part # |
01-04-2016, 09:58 AM | #27 | ||
Rep 263
2007 Lexus ES350
01-04-2016, 07:40 PM | #28 |
Rep 263
So I installed bulbs that I ordered from Amazon, but the rear dome isn't 100% flushed, it's hanging slightly out. Any solutions? PLEASEEEEEEE.
2007 Lexus ES350
01-05-2016, 03:32 AM | #30 |
Rep 25
01-05-2016, 03:35 AM | #31 | |
Rep 25
The plastic tabs are all ok ? The spring tabs are all ok ? not bend ? You mentioned that you have broken the dome, where is the damage ? Please be careful, the headliner is pretty difficult to replace. |
01-05-2016, 04:12 PM | #32 | |
Rep 14,521
01-05-2016, 07:36 PM | #33 | |||
Rep 263
annoying because I want to do things to the car but I feel like I'm incapable of such things. Tell me about it.
2007 Lexus ES350
01-06-2016, 12:12 AM | #34 |
Rep 14,521
Practice makes perfect! But eventually it comes to a point where it's probably best to have things done the right way the first time around
01-06-2016, 02:54 AM | #35 | |
Rep 25
To rectify the troubles, I would suggest that you take it to BMW dealer for; - Replacement of the broken dome. - LED kit from BMW + services installing the 10 LED from the kit. If they are not aware about the LED kit, you can show them following (set of 10 => 6 for front and rear dome, and 4 for door; I am not sure about the part # of the dome, this needs double check. Last edited by cm048; 01-06-2016 at 05:29 AM.. |
01-06-2016, 08:36 AM | #36 |
Rep 3
I used the ECS Tuning F10 LED kit on my 2016 BMW 550ix last weekend. I ordered the trim removal kit with it as well.
https://www.ecstuning.com/News/BMW_F...013/ES2576040/ The kit has a very detailed installation document with it: http://bd8ba3c866c8cbc330ab-7b26c6f3..._LED_Light.pdf The only issue I ran into was on the 2016 F10 the foot well lights are already LED but they are a yellowish LED. There isn't any bulb to replace so I need to do some research and find something to replace the entire part with so I can put a bright white LED bulb in the foot wells. I also installed 2 pair of the //M projector LEDs into the doors. I purchased them off of Amazon from a company called LUMAND. They were plug and play and add a pretty nice effect at night. http://www.amazon.com/LUMAND%C2%AE-C...tor+door+light Image of the post install look can be seen here: http://1drv.ms/1OMAHgV Hope this helps. LB |
01-05-2017, 12:30 PM | #37 | |
936
Rep 4,327
Drives: M340
Has anyone installed the OEM 10 bulb LED replacement kit directly from BMW mentioned above? I think I am going to pull the trigger and order this as it is OEM and I know that all the lights will perfectly match. Also I would rather stick with OEM for the price that ECS is asking for aftermarket. Any feedback would highly be appreciated.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
01-06-2017, 12:53 AM | #38 |
Rep 105
Since this post is back I have a random question.
Anyone know if the LCI F10's have halogen lightbulbs in the puddle lights? Or are they yellow "strips?" I want to replace mine with some LED bulbs but I don't know if there are even bulbs to be replaced. The easy solution would be to look at my car, but I'm out of town for 10 days so wanted to order it for when I get back. |
01-06-2017, 09:47 AM | #39 | |
936
Rep 4,327
Drives: M340
01-08-2017, 12:03 AM | #41 |
Rep 5
Halogen?
I haven't updated the lights in my 5 yet. I did change the lights in my Land Rover. However, I chose to leave the map lights and footwell lights as is...for better night vision. I changed the front, middle and cargo dome lights as well as the puddle lights, to LED. The set up works pretty well and I am not blinded when driving at night and my wife uses the map light. I'll definitely go ahead and swap out the puddle lights on my 5 to LED. |
01-08-2017, 09:13 AM | #42 | |
Rep 891
2021 MBB M5C (retired) 2018 Daytona Violet M3 ZCP (retired), 2016 AW 550i (retired) 2013 EBII 335i (retired), 2008 Platinum Bronze 535xi (retired), 2007 Monaco Blue 335i (retired) 1999 Hellrot M3 coupe (retired) |
01-22-2017, 10:55 PM | #43 |
Rep 154
Did the full kit, $25 on eBay. Very happy with the results. Be careful with map lights as they can bend the metal housing with the LED boards.
