2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Has anyone figured out how to fix a PWG N55 wastegate rattle?
      07-31-2018, 04:56 PM   #1
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
So I’ve searched and searched and read every thread on E90Post, 1addicts, F10/30/80posts, and still haven’t found an answer. It seems like there are solutions to the N54, and the EWG N55 is an easy fix via tune, but I haven’t found anything specifically for the PWG N55.
I have THE WORST wastegate rattle. I was hopeful that a tune would help but no dice.. it has gotten worse as mods progress. Currently I have: MPE exhaust, catless DP, charge pipe, intake, and BM3. The cold start delete is amazing for startup rattles, but i have a rattle from 10-90% throttle all the time. Light acceleration and full boost/WOT sounds amazing. When cruising in gear at ~2400 rpm it’s a constant flutter/rattle, on de-acceleration I hear it, every burble I hear it. If I put the car and gear and rev it to 1200 rpm it’s obviously constant. Classic “coins in a tin can” sound.
Local shops say they don’t have a fix (granted HI has shitty local shops), and I’ve spoken with Turbo Labs and they have yet to work on one, but they do make kits to fix it for the N54. They’re going to see what they can find out for me.
So, all that being said, anyone have some good info? This is my #1 priority right now as it’s driving me insane throughout my hour commute.
I know, I know
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      08-09-2018, 10:55 PM   #2
bluefa5
Drives: 2013 Bmw 535i M-Sport
Bump, also have the same issue and need a solution
      08-15-2018, 12:55 PM   #3
5soko
5soko's Avatar
333
Drives: M5
Yea these PWG with catless DP's really hear that whistle or very fast wastegate rattle on partial throttle.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      08-15-2018, 03:26 PM   #4
Shieldze1025
Drives: F10 535i
Yup! Exactly what I have going on. When the wastegate closes under heavier throttle it sounds amazing
-Mario Andretti
      08-15-2018, 07:31 PM   #5
AZ-MCRacer
AZ-MCRacer's Avatar
306
Drives: 2022 G82 M4, 2013 F10 N55
Wire it closed 100% of the time.
Please don't anyone take me seriously on this.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD!
1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped
      08-16-2018, 06:28 PM   #6
Shieldze1025
Drives: F10 535i
Hahahahaha I’ll just run open wastegates and push 40 psi
      08-22-2018, 12:09 PM   #7
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
putting stock downpipe and stock exhaust back on car may make the noise a lot less noticable....
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      08-27-2018, 12:24 AM   #8
19E92
19E92's Avatar
Drives: '07 335i / '11 535i xDrive
Has anyone tried wrapping the downpipe in heat wrap to see if it masks the sound? I'm having the sane problem after DP install on my 2011 F10 N55 Pwg. Will try heat wrap in the next couple of weeks and report back.
      08-29-2018, 02:24 PM   #9
Shieldze1025
Drives: F10 535i
It could help! I've been trying to figure it out, although I've been busy dodging a hurricane, I noticed that the noise definitely resonates from the Turbo/DP area itself, not the exhaust exit.
I haven't had time to drive to a few indy shops, they're all about an hour away. But still no luck on my end. Best solution I can find right now is upgrading to a PS1 or PS2
-Mario Andretti
      09-07-2018, 06:09 PM   #10
19E92
19E92's Avatar
Oh jeeze, I hope you're safe and sound!
Update for you! I wrapped the DP and there was a minimal decrease in noise. If nothing else, engine temps should be a little better now.
I'm going to see if bootmod3 can create a rattle fix.
      09-11-2018, 04:46 PM   #11
Shieldze1025
Drives: F10 535i
Ah, bummer to hear that. so far BM3 did not help I thought the extra boost would help hold the wastegate open or closed better but not at all. Pretty sure the bushing is shot. I reached out to turbo labs, I need to follow up with them.
      07-01-2019, 10:01 AM   #12
e46m3to335i
e46m3to335i's Avatar
Drives: 2015 F80 M3
I know, I know
Any details on how this is an easy fix via a tune adjustment??? I'm experiencing wastegate rattle during light acceleration.
-Nick
      07-17-2019, 01:25 PM   #13
Shieldze1025
Drives: F10 535i
-Nick
I've been yold you can program the % for the EWG through certain tunes, but I really don't know as I have a PWG.
Mine is still a pita... hear it every day.
-Mario Andretti
