2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Are all F10's pre-wired for rear heated seats?
      01-14-2021, 10:01 PM   #1
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Have the opportunity to swap my rear seats for the split folding seats. The rear seat is also heated and my car wasn't spec'd with rear heated seats. Will this be as easy as finding a tucked connector for the heating elements and then replacing the rear center console with a version with the rear seat heater buttons and plugging those in to a tucked connector? Or will those connectors not even be present??
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      01-14-2021, 10:19 PM   #2
Originally Posted by bake View Post
Have the opportunity to swap my rear seats for the split folding seats. The rear seat is also heated and my car wasn't spec'd with rear heated seats. Will this be as easy as finding a tucked connector for the heating elements and the man replacing the rear center console with a version with the rear seat heater buttons and plugging those in to a tucked connector? Or will those connectors not even be present??
No. You will need wiring harness(es), switches and probably more miscellaneous stuff. Add coding after that.
      01-15-2021, 08:50 PM   #3
M_Bimmer
M_Bimmer's Avatar
730
Drives: F02 B7, G12 B7, G07 XB7, 911
To the OP, there are two versions of the rear heated seat "buttons"....
1. Embedded in the 4-zone Rear Control Unit
2. Two Buttons under the rear center vent (pictured below)
#2 would be the easiest to MOD for your car, but still would require you to run wires:
- For the Buttons:
- - Power from JBE, Fuse F31, to rear of center console to both switches
- - K-LIN from JBE to rear of center console to both switches
- For the Heat Modules (under the seat cushion)
- - Power from rear fuse box, F188, to rear driver's side module
- - Power from rear fuse box, F187, to rear passenger's side module
- - K-LIN from buttons to both modules
You'd need to find a rear vent trim that has the two holes for the heat switches, and then switches.
You could do this at a later time after you've installed your split rear seat...
      01-15-2021, 09:58 PM   #4
bake
bake's Avatar
- For the Buttons:
Thanks for this info, it is extremely helpful. I think I will still go through with retrofitting the folding seats, but probably won't bother with getting the heated seats functional. At least not at this time. If COVID continues to drag on into the summer, maybe I'll decide to take on that project, but I have enough going on right now.
Bake
      05-15-2024, 10:53 AM   #5
furkan24
Drives: 04’ E46 330CD 10’ F10 530D
- For the Buttons:
Hello. I have 4-zone Rear Control Unit. I need wiring diagram. Please help me. Thanks
      05-15-2024, 08:47 PM   #6
M_Bimmer
M_Bimmer's Avatar
730
furkan24 mind sharing your F10 manufacturing date? Wiring may depend on it.
      05-16-2024, 07:22 AM   #7
furkan24
My car 2010. . Power and ground wire okay. Rear fuse 187 & 188 power . But I don't know where the 2 yellow and 3 brown cables will be connected.
      05-16-2024, 07:25 AM   #8
furkan24
https://files.fm/u/kdznr82mgf
https://files.fm/u/prsk98js6a
      05-16-2024, 09:56 PM   #9
M_Bimmer
M_Bimmer's Avatar
730
Hard to tell what that wire loom is coming from....
Here is the 1st schematic....and if you need more info on this module, let me know. Rear Seat Heater Module will be provided in the next post.
      05-16-2024, 10:59 PM   #10
M_Bimmer
M_Bimmer's Avatar
730
Rear seat heater wiring for the F10.
