2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
06-03-2022, 11:59 AM | #485 |
Rep 2,590
Decided not to go the router option just to explore other options. Turns out, a file will make pretty quick work of aluminum as well. This is after about 20 minutes of filing. Smoothed out with 350 grit afterwards to make sure the file marks don't show up after powder coating.
If you go with filing, I recommend spraying the area down with some kind of guide coat - either actual guide coat, or just a cheap spray paint. Helps a lot in seeing where you're going with the file.
2015 BMW 535xi
Blue Angel997.50 |
06-05-2022, 04:13 PM | #488 |
Rep 2,590
Oh wow, that's pretty sharp. Definitely a more subdued look
2015 BMW 535xi
ptrkp18.00 |
06-09-2022, 07:33 AM | #490 |
Rep 34
Had some logos but they where the wrong ones, not sure I will put any on it.
And picked up my new brakes lines that they made for me. |
Blue Angel997.50 3002 tii2282.50 |
06-11-2022, 11:57 AM | #491 |
Rep 34
With logos.
Blue Angel997.50 |
06-12-2022, 05:59 PM | #493 |
Rep 2,590
Personally, not a fan of the shaded M logos. IMO flat gradient ones look far better
2015 BMW 535xi
07-10-2022, 03:21 PM | #494 |
Rep 167
Finished with the front, 760i used calipers, new pads and discs
Thing is massive while still fitting a 19" wheel in. Question::::::::::::::::::::::???????????????? Can I use my old front calipers on the rear? I believe they are the same as the 535i (US) My car is a 530d eu spec. |
07-10-2022, 04:30 PM | #496 | |
Rep 2,590
2015 BMW 535xi
07-10-2022, 04:58 PM | #497 |
Rep 167
07-10-2022, 07:48 PM | #499 |
Rep 1,356
One option is to use M5/M6 caliper with 370 rotors. They are direct bolt on. No spacer or anything.
Left Caliper 34217845815 Left Carrier 34217848315 Right Caliper 34217845816 Right Carrier 34217848316 Rotor 34216775291 |
Blue Angel997.50 |
08-13-2022, 08:02 AM | #501 |
Rep 1,044
Have a 535i and I need to do a brake refresh. Picked up some calipers from a 750li with the “929” stamped carriers which from my understanding are the correct ones. My question is are you guys changing out the dust shield behind the rotor?
08-13-2022, 08:21 AM | #502 |
Rep 167
I didn't had any issues with the shield, mine was the alpina 760 ones
374mm L: part n. 34 11 6 789 543 (34116789543) R: part n. 34 11 6 789 544 (34116789544) |
08-18-2022, 12:35 AM | #503 |
Rep 2,590
I did not need to change out my dust shield, in fact I believe all 5/6/7 series cars share the same shield.
2015 BMW 535xi
09-16-2022, 08:15 PM | #504 | |
Rep 2
09-16-2022, 10:49 PM | #505 |
Rep 1,037
No brackets, just some 12mm or 1/2" washers to space the caliper out a little since the G-series cars have a slightly different offset.
I originally had two thick stainless washers per bolt, but then got the recommended single Case washers which are 4mm thick. I just installed these the other day, and let me tell you these are the absolute thinnest washer that will work. With these the pads won't go into the outer side of the caliper unless the pistons are COMPLETELY bottomed in the caliper, and are pressed against the rubber dust seals once installed. I recommend a spacer at least 5mm thick if you plan to track your car, bed in your brakes, or do anything that gets them really hot. Also with the 4mm washers, I wouldn't recommend using the pads until they are completely worn out since the inboard side pistons will be sticking quite far out of the caliper by the time the friction material is gone and the rotor face is worn to minimum. Maybe I'm a little paranoid for a street driven car, and for the record I'm likely going to keep the 4mm washers. BUT, I will be keeping an eye on things as the brakes wear. |
10-04-2022, 08:16 AM | #506 |
Rep 34
B-Buster24.00 Blue Angel997.50 |
