2010 2011 BMW 5 Series Forum F10 Coilover Recommendations |
02-21-2022, 10:56 PM | #1 |
Rep 81
Hey y'all, I wanted to ask what coilovers you all are running or have experience with. I'm not looking to spend too much but at this point I understand that KW V1s or BC coilovers are the recommended options with a price of around $1200. I'm curious to know if anyone has experience running any cheaper alternatives like Megan or GodSpeed Coilovers ($750-$990). Any advice or input is appreciated, hoping to lower my car soon (RWD).
02-22-2022, 09:08 AM | #2 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Bilstein B12 was always my go-to coilover kit for every car I've owned until I got my 550i and realized they don't make it for the xDrive. You can't beat the quality and performance for that price range. Just my 2cents.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
02-22-2022, 09:39 AM | #4 |
Rep 233
I have KW V3s on an Xdrive car. Really superb adjustability and great handling with zero body roll. Not cheap, but as Ben Franklin said, "Quality is the only bargain".
Good luck. |
02-22-2022, 05:12 PM | #6 |
Rep 233
The KW is impressive because it allows tuning of the low speed bump and rebound while retaining great high speed performance. I have the bump near the soft limit owing to Chicago pavement and it still feels great on the interstate.
FWIW, My indie said he wished he had done them on his wife's bimmer instead of the Bilsteins. |
02-23-2022, 08:18 AM | #8 |
Petrolhead
440
Rep 808
To be clear, I'm 101% pro KW and love my V3s. If you're spending that much money, then V3s are the way to go. However, if you're looking for something in the $1,200 range, I still say the B12s are the best bang for the buck, especially since Bilstein struts are mono tube and can be found for <$1k.
gr8brwnshark26.50 |
02-26-2022, 12:33 AM | #9 | |
Rep 81
02-27-2022, 08:02 AM | #11 |
Rep 1,037
I have the Neomax with Swift springs and they're good, but not great. IMO they need more low speed compression damping. I have them set at 18/24 both front and rear which is about my tolerance limit for ride harshness, and body control over larger dips/dives could still be better.
Based on experience lowering every other car I've owned, they are hands-down far superior to a spring-only setup on original dampers, and the ride height adjustment is awesome to have. I can't comment whether KW are worth 50-100% more money, but judging on reviews the V3 version certainly seem like they're better. |
02-27-2022, 12:12 PM | #13 | |
Rep 1,037
One thing I'm not sure about still is the spring rates. The KW V3 has softer springs than the Neomax, and I find the Neomax to be about the bare minimum on my lowered F10 which is not even that low. The V3's ability to have more low speed compression damping would certainly make up for some of that, but I honestly wonder if I had the V3 if I would want a slightly stiffer spring. I can only assume that they have it very well set up for this application as most people are very happy with them. |
02-27-2022, 12:15 PM | #14 |
Rep 2,590
The V3's aren't just softer springs - they're a different type of spring altogether. Neomax uses linear springs, KW uses progressives.
2015 BMW 535xi
02-28-2022, 03:12 AM | #16 |
Rep 81
Sounds like a lot of folks have experience with the v3s, v1s will have the same adjustment features as well, correct? (without as high as quality of the v3 of course) Everyone's comments are definitely pushing me towards the KW side but it'd be the v1s for sure. Pricing is definitely something I'm taking into account so that's not to say neomax, bilstein are off the chart just yet. Don't think I've heard anyone's experience with the V1s either anywhere
02-28-2022, 06:29 AM | #17 | |
Rep 1,873
V2s are rebound adjustable V3s are compression and rebound adjustable V4s have high and low speed adjustments for compression and single adjustment for rebound (but there isn't an F10 application). https://www.kwsuspensions.net/produc...et_performance The only kit KW made for F10 X-Drive is V3 (which is partially why you see a lot of V3 comments). Last edited by Surly73; 02-28-2022 at 06:57 AM.. |
Blue Angel997.50 gr8brwnshark26.50 |
02-28-2022, 05:10 PM | #18 | |
Rep 2,590
2015 BMW 535xi
Blue Angel997.50 |
03-28-2022, 02:23 AM | #20 |
Rep 14,522
can't go wrong with KW's. Been on my V1's for more than 6 years now!
06-02-2022, 02:55 AM | #21 |
Enthusiast
291
Rep 275
Drives: 2025 M4 Comp xDrive
KW v3 no longer sold?
Hey guys
I'm trying to purchase the KW v3 coilovers but cannot find them on kw site. I contacted them via instagram and they say they are no longer made and that they may show up as being available on vendor sites but that's outdated and no longer available Is this true? Has anyone purchased them new this year I have x drive so need kw V3 Otherwise it'll have to be neomax i guess
2025 M4 Competition xDrive
IG: Automaz_ |
