2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Shocks/springs
      09-22-2018, 11:19 PM   #1
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Shocks/springs
I have a '12 550 with the electronic Adjustable suspension. Which shocks/struts/springs should I go with??
      09-23-2018, 06:00 PM   #2
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I went with H&R Springs, it still works for everything and no error codes.
      09-24-2018, 10:53 AM   #3
535_BiTurbo
Do you have the part no?? Does it includes the struts as well?
      09-24-2018, 10:59 AM   #4
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
These are the ones for your car: https://www.tirerack.com/suspension/...+Sport+Package
No it does not.
      09-24-2018, 11:56 AM   #5
535_BiTurbo
I wonder if I can run M5 struts?
      09-24-2018, 05:19 PM   #6
addy27
Drives: F10 550i
First off..before modifying anything else..I'd recommend getting the Dinan shockwave installed. it makes a clear difference in the bobbing and weaving of the car in turns.
I highly recommend ANYONE with a F10 with adaptive suspension should try it out If that isn't enough, add Dinan or ACS springs...
If you need new struts, you can decide to either kill EDC and go the KW Coilover route with EDC delete..or replace with stock. No-one other than BMW makes EDC compatible struts.
      09-26-2018, 12:55 AM   #7
535_BiTurbo
So M5 struts/shocks wont work?
      09-26-2018, 07:47 AM   #8
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I would say no.
I would recommend upgrading the shocks as the OEM weren't designed for lowering springs and have been noted here by members of failed/leaking shocks within a short period of time. If budget allows I would invest in coilovers as they are designed and engineered for performance and the ability to set the height to your liking
