2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Drivetrain error
      06-13-2018, 04:40 AM   #1
dessmfc
Drives: F10 Lux Auto Touring
Drivetrain error
Had my car 6 weeks and this has appeared 6 times now. Each time it has gone out within 10secs and leaves no trace. There is nothing on the Check Control, nothing on the error codes in the 'secret' dashboard entry and I have checked with my OBD device and nothing shows up.
The first 3 times it showed when I was on cruise control on the flat, no real acceleration. Then it went quiet for a few weeks. Now, it's shown up under acceleration, although not particularly harsh.
I've read earlier posts and other forums, but none describe the error where it just disappears. Is this really something I should worry about, or could it just be hesitation in a valve or something similar?
If I take it to BMW, there won't be anything to show them on the OBD, or do they have more intrusive equipment?
      06-19-2018, 01:13 AM   #2
dessmfc
Having had it appear a few more times, I took it back to the service centre. They diagnosed it as 'charge air pressure too low', and said it would need a software update, which would take a few hours, to be done another day.
Doing some research, this appears to be less of a software issue, more of a leak issue, with others having loose couplings and split hoses etc
Any ideas?
Junebug851615.00
      06-19-2018, 02:56 AM   #3
Aletank
Aletank's Avatar
Drives: 2016 520d M-Sport
EGR Valve is the most common issue - i had mine replaced under warranty not so long back. Service guy said they do loads !
Dec 2016, BMW 520d M-Sport Auto
M-Sport Plus Package
Professional Navigation Multi-Media
Split/Fold Rear Seats
Space Grey, Oyster Leather
      06-28-2018, 09:33 AM   #4
dessmfc
Fixed, fingers crossed.... Turned out to be a hairline crack in the gas collection chamber. They replaced that and the .....EGR valve, surprise, surprise.
      07-01-2018, 07:02 AM   #5
dessmfc
Not fixed... Drivetrain error still showing. Had enough now, might get rid.
      08-14-2018, 08:35 PM   #6
dessmfc
Still regularly popping up on system 'Drivetrain Error, drive moderately..blah, blah' but no loss of power or codes in system. I'm inclined just to ignore it as a glitch but it may become an issue when I try to sell, I suppose.
      08-16-2018, 10:56 AM   #7
Aletank
Aletank's Avatar
If it's under warranty, get it fixed ! Go to a different dealer if your having no luck at the current one
      08-17-2018, 01:13 PM   #8
robbiep
Drives: VW e-Golf !
Even if there is no record of the fault being retained, you DO have the display when it happens, and (almost certainly) a phone with a camera on it ... I'm sure you can put the rest of it together.
You have the legal RIGHT to have the car repaired.
      08-20-2018, 01:59 AM   #9
dessmfc
Sound advice, but guess where I bought mine?
      08-20-2018, 05:03 AM   #10
Aletank
Aletank's Avatar
Is it not under the 3 year BMW warranty ? how old is the car ?
      08-22-2018, 12:49 PM   #11
dessmfc
No, I was daft enough to buy from Big Motoring World, and they haven't exactly covered themselves in glory with their customer service. They've had the car four times and nt found the fault
      08-22-2018, 01:45 PM   #12
robbiep
Drives: VW e-Golf !
That's OK, because you show them the fault as recorded, therefore proving the fault exists. You then explain to them (possibly using really small words and speaking very slowly) that you know your legal rights, and you therefore expect them to investigate the fault properly.
If they don't feel they are competent to investigate the fault, then you can even help them out by telling them that you're entirely willing to take the car to a BMW dealership for investigation ... at their expense.
      08-25-2018, 01:43 AM   #13
dessmfc
Problem being, there is no fault recorded. The error message disappears after 10secs and doesn't stay on the system or visible on a DTC reader.
