2010 2011 BMW 5 Series Forum F10 BMW M5 to F10 DIY Brembo Brake conversion |
08-01-2017, 06:19 PM | #45 | |
Rep 1,158
shhhhh...
I've send you several PM on this seller, but i never get any respond. I guess either you don't want to share it with everyone or you're just too stingy... either way, good luck with your build man. I'm on the market for a F/R brackets as well.
BMW f10 550i Msport
08-07-2017, 12:06 PM | #46 |
Rep 1,084
First Page has the URL's for seller. And in that link the email contact is listed. The email is: Николай Троценко <tronik75@gmail.com>
I have sent the URL, which has the email address in it, several times. This information is in my posts as well. The gentleman is in Russia I believe so you may have to do a google translate. If someone does not want to go to the URL and look up the Email it is: Николай Троценко <tronik75@gmail.com> Last edited by mikekilpatrick; 09-06-2018 at 07:00 AM.. |
10-03-2017, 08:26 AM | #48 | |
Rep 3
I read somewhere you also now make adaptors for "stock rear calipers" to take the m5 rear bigger rotors is that right?? will be contacting you by email shortly thanks. Last edited by mr0300; 10-03-2017 at 08:36 AM.. |
12-16-2017, 08:01 AM | #49 |
Rep 75
02-02-2018, 01:10 PM | #50 |
Rep 25
I'd like to do this for my 2010 F07 550ix, how would it be different than installing the M5 brakes on a F10, especially for the rear.
Thanks in advance fellas. |
05-21-2018, 12:52 PM | #52 | |
Rep 43
06-08-2018, 06:23 PM | #53 |
Rep 193
Same here ☺️
09-05-2018, 11:43 AM | #55 |
Rep 14,521
09-06-2018, 01:30 AM | #56 |
Rep 1,084
Pics of Install
Bump to top to show install pics. I will document everything and post here. There is a considerable amount of prep work to make sure you have all the right parts ready. You will need M5 Brake lines front and back, Rear M5 Brake line clilps, Front Rotor Bolts to hold to axle, have a dremel ready to cut the brake dust protectors, have a 9 MM HEX socket ready as most sets only have a 8mm and 10 mm in them, and a few other little tips and tricks. Also highly recommend a pressurized bleeding system so one person can bleed brakes.
09-08-2018, 04:12 PM | #57 |
Rep 1,084
Rear adapter clearance issue
So, it looks like the rear adapter brackets are off 2-3 mm on my car. Did anyone else have issues mounting the rear adapters? I thought at first I might have had the wrong bolts cause the body shop lost my original M12 1.5 x35mm bolts. But it looks like this is an issue with the start bolt.
The top star bolt that inserts from the car side into the Brake pad assembly will not clear the axle mount. This was fixed by removing 2-3 mm of material from the axle with a Dremel. Just make sure you dont go into the Mounting bolt mounting face. Then ensure you smooth off cut to prevent a cracking surface. Last edited by mikekilpatrick; 12-10-2018 at 11:36 AM.. |
06-16-2019, 05:00 PM | #59 |
Rep 264
Hi gents. I don't venture into the 5series forum often, but I have a set of blue front M5 calipers if anyone is looking. They should be rebuilt as at least one of the seals is leaking, but I have not had time to mess with them. I have seen full rebuild kits for both calipers for $500 including new pistons. PM me with an offer if anyone is interested. If not, I may save them for when I pick up an F10 of my own.
06-17-2019, 09:45 AM | #60 |
Rep 342
Just read through the thread. It talked about the rears being 4 piston calipers, but pic above shows standard 1 piston? Skipped the brembo rear? I was wondering if there was a brembo rear that worked with the electronic parking brake on the f10 (does M5 rear have electronic parking brake too?) I have a stoptech bbk in the front, and would consider an upgrade for the rear if available...
06-17-2019, 12:48 PM | #61 |
Rep 1,084
One Piston Rear brakes, any mention of 4 piston was a typo. The rear Caliper IS IDENTICAL to the M5. The only difference is the rear brake pad assembly. Thought I mentioned that somewhere. You could use your existing caliper and add the Brake housing holder if you can find the part. Of course it would need to be painted blue. You will still need adapter to move the Caliper housing away from Hub to accommodate the bigger rotor though. You can also purchase OEM adapter from Person mentioned earlier in this thread and use existing caliper and brake housings and the adapter will mover the assembly to proper distance. And yes, M5 and non M5 all use Electronic brake.
02-07-2020, 06:43 PM | #62 |
Rep 1
I have a BMW 550i F10 2014 and I have found a Porsche Cayenne 2006 front brembo Z18 caliper for a very good price. Anyone know how I can fit them in my car or any kit or adapters available
02-09-2020, 11:07 PM | #63 |
Rep 1,442
Drives: 2011 535i 6MT
This looks interesting. What was your all in cost mike?
03-03-2020, 03:00 PM | #64 |
Rep 1,084
Probably about 2000.00. I got the calipers and pads/rotors on the cheap, then had them repainted, then the adapters. Been on the car for about a year with no issues.
06-13-2021, 10:58 PM | #65 | |
Rep 7
hi
06-13-2021, 11:01 PM | #66 |
Rep 7
hi all... amazing work guys, i just got my 535i about 9 month,
done installing brembo 19z on my car, but i feel the brake is way more softer than the original, if the master cylinder is help, any chance i can have the part number so i could find it and replace. or is the 19z make the brake feel soft???appreciate it... |
