DIY: front bumper removal non m w/ pictures!
Thread Tools |
| 10-22-2015, 01:49 AM | #1 |
Rep 14,537
9 pages i went through and nothing with pictures! anybody have a link or did i just miss it? appreciate it guys!
Okay...decided to post a DIY with pictures for those of you who are contemplating doing it yourself. 1) "Pop the hood" as how our fallen brother Paul Walker said to Vin Diesel 2) locate the rubber seal just above where the bumper and Hood meet ![]() 3) Peel the rubber gasket completey off CAREFULLY ![]() 4) there are 4 of these pull/push type fasteners u need to remove. I used a small pliers but just pull the pin up like so and wiggle it as both parts should come up ![]() 5) next there are 4 T30 torx bolts that need to be removed ![]() 6) now next step would be to turn your wheel in depending on which side you're working first ![]() 7) there are 3 screws you will need to remove inside the fender wheel using a 5/16" socket ![]() Bottom ![]() Middle ![]() Top right where the fender/bumper meet 8) here is where you'll need to go next...where the fender meets the front bumper. Doesn't matter which side you do first as they're both the same. As you can see I popped the fender liner open a bit ![]() 9) there are 2 more 5/16" screws to remove...the one all the way inside takes a bit or work as you really have to pull the fender well out and in a bit to get to. Up can see the screw next to my thumb ![]() The 2nd one you can see way up inside ![]() 10) had to google these next images but next remove lower grills. Pull them with your fingers as they are just snapped in like so ![]() 11) remove the 2 5/16" screws ![]() 12) disconnect the fog lights from the harness by simply squeezing the tabs and pulling out. I put the fog lights in my trunk so I don't scratch the lens ![]() 13) last thing is to remove the 8 5/16" bolts underneath ![]() 14) now all you have to do carefully is wiggle the bumper off and that's it. Install is the same. Hope that helps everyone as I searched all over the internet for DIY with pictures and came up empty
![]() ~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 11-09-2015 at 02:14 PM.. |
| 11-09-2015, 12:47 PM | #3 |
Rep 14,537
NO...but I could probably take some pictures and do a DIY?
![]() ~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
| 11-09-2015, 12:48 PM | #4 |
Rep 263
It's always up to you and your time! But it'll be nice for members!
2007 Lexus ES350
2007 Lexus RX350 2005 Lexus ES330 1972 Mercedes Benz 280 SEL 2014 BMW 550i |
| 11-09-2015, 02:17 PM | #5 | |
Rep 14,537
| 11-09-2015, 02:46 PM | #6 |
Rep 263
This was very well made! Thank you!
2007 Lexus ES350
| 11-10-2015, 02:17 AM | #7 |
Rep 668
Very good guide
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5, Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff |
| 03-12-2016, 01:46 PM | #8 |
![]() 14
Rep 90
Nice write up, thanks. I will be installing my Beltronics STi-R+ when I can find some time to do it. I don't think 3M tape is going to work well holding the radar receiver to the bumper housing. I'd rather bolt it on.
2007 M5, 6 speed, Silver Gray Metallic, Full Black Merino Leather, Brushed Ti Trim, HUD, Active M Comfort Seats/Heated & Cooled, Navi, Premium Sound, HK L7, Active Steering/Suspension, PDC, Rear & Side Sunshades, Adaptive Bi-Xenon, Voice Command, Custom S/W, Passport 9500ci w/jammers, Dinan High Flow Air Mass Meter/Intakes, CF Front Strut Brace, S1 Suspension & Free Flow Exhaust, Evolve S2 Tune
| 03-12-2016, 03:32 PM | #9 |
Rep 14,537
As long as you clean the surface very well the 3m tape will hold very well! But if you can find away to bolt it on than kudos!
| Bookmarks |
| Thread Tools | |
