2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Latest Theory on Why I Lose Windshield Washer Fluid
      01-04-2016, 09:08 PM   #1
Tasmanian
Tasmanian
Drives: 528Xi Tasman Green
Car is a 2012 528Xi. On warm days, I could fill the washer tank up to the top and within 40 miles, I am down 13 ounces.
I must commend my local dealer as they twice took the system apart to try to find the leak, including the typical leaky pump, leaky headlight tubes, etc. No problem was found.
Theory: the location of the turbo is superheating the blue washer fluid, causing it to evaporate.
Evidence: I find washer fluid dripping off of the inside of the top of the hood and then, cooling off and lying on the strut tower and lower control arms.
By opening up the tank, you can actually feel some of the condensation by the top of the cap.
So…is there insufficient heat shielding around the turbo? Is the turbo too close to the washer tank?
Anyone have any thoughts?
Thanks
Tasmanian
      01-04-2016, 10:47 PM   #2
Thanks
Tasmanian
That much heat generation would cause other problems..
      01-05-2016, 12:19 AM   #3
Gilgorm
Drives: 2018 640i Xdrive GT
It's hard to believe the turbo would be hot enough to virtually boil off the fluid. Every car in a hot climate would be out of fluid in a few days.
It is commendable that the dealer has put some time in but something must be leaking.
1) Have you filled up the tank and let the car sit for a few days? Or 2) driven it without using the washers?
If fluid is gone from question 1) then the turbo and driving has nothing to do with it. The system is not pressurized unless the pump is activated. I would drain the expensive?? fluid and put in water and try the system with the hood open. You may find a pinhole in one of the nozzles or tubing. If that reveals nothing then turn the headlights on and try the headlight washers and watch for tell-tale leaks (again with the hood open). A small hole under pump pressure should be obvious in either location.
On a retired MB, I had a problem with a heated nozzle with a tiny pinhole that only showed up under pressure. With the system off nothing ever appeared.
Also, is the tank cap tight and seated properly?
Good luck.
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive
      01-05-2016, 12:21 PM   #4
snowmuch
Drives: 2016 Macan Turbo
I'm having the extract same problem and it's very annoying. Is this common with f10s?
C300->C63->535->S4->M4->Macan->Macan Turbo
      01-05-2016, 02:01 PM   #5
HighlandPete
Drives: BMW F11 535i Touring
There must be something wrong for fluid to be lost, certainly not a normal issue for an F10/11.
If, and to me it is a big if, it has something to do with the heat from the turbo; my first question is, are all the heat shields in place? Second must be, how does it get rid of all the fluid?
I'd be looking for a split in the tank, may open up when warm and fluid spills/leaks, blown around by the airflow.
Has anyone put a low pressure test on the fluid reservoir, to eliminate a leak from the system itself?
HighlandPete
      01-05-2016, 04:11 PM   #6
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
how funny is that...mine just came on today but i know mine is because i'm always cleaning my windows from all the bugs hitting the windshield earlier this summer and fall.
      01-05-2016, 04:13 PM   #7
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
I had my tank, then pump, then lines replaced and finally it stopped leaking - there were never any drips or puddles on the garage floor. Who knows what happens in the far reaches of the service department.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
TrqAdct22.50
      01-06-2016, 08:09 PM   #8
Tasmanian
Tasmanian
Next Step..
Since the washer fluid is condensing on the underside of the hood, my next step is to replace the flip lid of the tank. I have not found any pinholes near the top. When it gets warm outside again, I can study the problem more carefully.
As far as I can tell, all the shielding is in place (if not, hopefully the dealer would let me know while checking the problem).
thanks
Tasmanian
      08-21-2016, 07:13 PM   #9
Tasmanian
Tasmanian
Smile It Was A Bad Cap!!! After 2 Dealer Visits That Coud Not Resolve It!
Two visits...no resolution! Finally...I studied where condensation was forming after a really hot trip.
And since I could not find a crack or flawl and where...I bit the bullet and bought a new cap for the windshield washer fluid. ..$9 from from the friendly parts man. Wow! No more windshield washer fluid loss!
I couldn't believe it was that simple! Others are having the same problem...so buy a Cap and try it out.
Thanks
Tasmanian
thanks
Tasmanian
      08-24-2016, 12:00 PM   #10
krautmeister
krrrraaauuuuut
krautmeister's Avatar
Drives: G12 750i X Drive M-Sport
G12 750i  [0.00]
Can I jump in here for a small tangent?
My old BMW dealer in my E60 used to use a fluid that smelled like mangos (or something pleasant) in the washer fluid. Is that not a standard thing? I don't have it in my F10.
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art
(Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx
      08-24-2016, 02:54 PM   #11
Perfectus
Perfectus's Avatar
35
Drives: e92 335i/F10 528XI
Thanks
Tasmanian
I'm having the same issue. Thanks for sharing the "fix"
Do you happen to have a part number?
2012 528XI Saphire Black
Stock for now
2007 e92 335i - Monaco Blue
Injen DCI w/ Cyba Scoop - M-Tech Rear - ///M3 Rear Lip Spoiler - ///M5 SMG Shift Knob & iDrive Knob - BMW Performance Hand Brake - BMWCCA Member
      08-24-2016, 04:12 PM   #12
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Welcome to midwest
      09-06-2016, 10:50 AM   #13
RSBro
RSBro's Avatar
Drives: 2012 550i M-Sport
My car is doing this and it's really annoying... I filled it up with a full jug of fluid on Saturday and by Sunday afternoon I was getting Warnings that it was all gone. Does it seriously evaporate if you drive hard? I was at the track all day Sat and Sun so would that have done it? I've never heard of an issue like this, much less in a $70k+ car. It's a little ridiculous. Also I used actual wiper fluid and not water, so how could that evaporate so fast?
I called my S.A. to get me in so it can get looked at because I'm tired of the damn bing going on 24/7 with that Warning.
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
      09-07-2016, 07:52 PM   #14
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Common on all turbo BMWs. I think the turbo evaporates the liquid. On my e90 I eventually developed a leak
IG: @bmwdoubles
      09-09-2016, 09:30 AM   #15
RSBro
RSBro's Avatar
For me it's only started happening recently though, and from what I can tell no leaks which makes it all the more frustrating.
      09-09-2016, 10:13 AM   #16
Infamouscrew02
Infamouscrew02's Avatar
75
Drives: 13 535 M-Sport
I get the same thing, dried washer fluid all around the bottle. Do you have a picture or a part number of the cap you bought? What store did you go to? AutoZone? BMW? Advance?
      09-12-2016, 04:09 PM   #17
RSBro
RSBro's Avatar
This is the BMW-branded washer fluid. You can buy it from a dealer or if you can find it online, get it there. I have to buy it in concentrate in TX for some reason.
But I agree- it's a dumb thing kinda, but it is pretty cool to have scented washer fluid. And then tell other people about it lol.
      09-23-2016, 07:27 PM   #18
Tasmanian
Tasmanian
Wink $9.00 Part
Hello
sorry I took so long to respond. I forgot to log in.
All I did was go to the BMW dealer, and asked for the new cap for my windshield reservoir. Popped it on the next day when it arrived...and haven't lost an ounce of fluid ever since.
Best $9 I ever spent...especially after 2 trips to the dealer proved worthless.
Tasmanian
      09-23-2016, 10:01 PM   #19
krautmeister
krrrraaauuuuut
G12 750i  [0.00]
Good deal... even if it cost 100 dollars... probably feels great to have closure....heee heee pun intended!
Kyngofpop676.00
      09-24-2016, 10:03 AM   #20
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
So are you saying that a cap that doesn't seal properly causes evaporation?
IG: @bmwdoubles
      10-01-2016, 10:59 PM   #21
Tasmanian
Tasmanian
Yes
We had evaporation through the old cap. The condensation actually snowed on the inside of the hood.
Tasmanian
      10-02-2016, 06:44 AM   #22
Breach
Drives: F10 520dA M Sport
Interesting topic. I guess it would be quite had to catch a leak given how fast the fluid evaporates...
