07-16-2016, 01:16 PM | #1 |
507
Rep 3,470
Spacers question
I'm a little lost these days in terms of spacers. I need to push out my wheels a tad to make it look just right but I don't know what size I should put on to make them just right. 15mm front, 5mm rear?
Current Setup 535i xdrive lowered on H&R springs Wheels: Front: 20 x 8.5 et +34 Rear: 20 x 10 et +40 Tires: Front: 245/35/20 Rear: 285/30/20 |
07-16-2016, 04:15 PM | #3 | |
507
Rep 3,470
07-16-2016, 04:50 PM | #4 |
Rep 14,521
Take a picture for reference
07-17-2016, 12:18 AM | #5 | |
Rep 91
Thanks.
2007 M5, 6 speed, Silver Gray Metallic, Full Black Merino Leather, Brushed Ti Trim, HUD, Active M Comfort Seats/Heated & Cooled, Navi, Premium Sound, HK L7, Active Steering/Suspension, PDC, Rear & Side Sunshades, Adaptive Bi-Xenon, Voice Command, Custom S/W, Passport 9500ci w/jammers, Dinan High Flow Air Mass Meter/Intakes, CF Front Strut Brace, S1 Suspension & Free Flow Exhaust, Evolve S2 Tune
07-17-2016, 11:53 AM | #6 |
Rep 29,203
Yes, 12mm or 15mm in the front, 5mm sounds good for the rear.
07-17-2016, 05:31 PM | #7 | |
507
Rep 3,470
Thank you remmib, I KNEW you'd come through! |
07-18-2016, 05:05 AM | #8 |
Rep 5,140
Your rear wheels are 13mm more aggressive than the fronts.
I would probably just do 10 or 12mm front spacers and skip the rears. In this way you can avoid buying rear spacers and messing with extended lug bolts for only 5mm lower offset. |
07-18-2016, 06:07 AM | #9 |
Rep 14,521
Agree...you're rears are already at a 40mm offset unless you're looking for that poke look
08-18-2016, 02:40 AM | #10 |
Rep 2
My Hartge Classic 2 @21"
- Front 8.5 x 21 (Offset 34) - Tires 255/30/21 - Rear 9.5 x 21 (Offset 55) - Tires 295/25/21 I believe i need to add spacer for more aggressive look. Need help/advise Thanks bro |
05-25-2021, 10:17 AM | #11 | |
Rep 179
Drives: BMW 535i F10
05-26-2021, 03:33 PM | #12 | ||
507
Rep 3,470
