2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Torque specs. F10 suspension
      08-05-2016, 04:07 AM   #1
Jrsimp78
Drives: 535i se auto saloon
Hi All , does anyone has the details of the torque spec. on the front wishbones. I have a manual that ref.s the below spec. I can't seem to find it anywhere.
31 12 20AZ
Any help would be greatly appreciated.
      08-16-2016, 02:49 AM   #2
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
front and rear torque. Did the dinan control arms..
      09-02-2016, 07:15 AM   #3
Jrsimp78
Thanks Mike. That's a great help
      03-22-2020, 08:53 PM   #4
bin01123
Drives: 2011 750i
2011 BMW 750i  [0.00]
2011 BMW 328I  [0.00]
About to replace struts. Does anyone have specs on bolts for the struts?
      03-22-2020, 11:10 PM   #5
Unspec
Unspec's Avatar
1504
Drives: 2015 BMW 535xi
For the ones that bolt it to the chassis? 28nm. Don't reuse the old bolts.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      07-09-2024, 10:53 AM   #6
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2007 BMW 328i E91  [10.00]
2009 BMW 328i E91  [7.56]
2006 BMW 330i  [8.17]
2007 BMW 328i  [8.83]
2013 BMW X5 35i  [8.43]
2011 BMW 528i  [9.07]
Thank you for posting this! I need to clarify which are the torque values for the front thrust arms? I see all those listings, and I don't know which is which! Both the subframe bolts and ball joint nut.
I need to swap these out, and have never done it on the F10. It's an easy job on an E90, so presuming the best!
Thanks!
      07-19-2024, 12:32 PM   #7
StradaRedlands
M_Bimmer gave a great answer to my question over on the main conversation page: https://f10.5post.com/forums/showpos...20&postcount=2
Thanks!
