F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Cruise control malfunction repeitive error code
ARMA SPEED
      09-18-2016, 09:50 PM   #1
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
21
Drives: 440i Gran coupe F36
Hello mates, I am asking regarding to a 'cruise control malfunction' code that constantly comes on and off randomly. When the code comes on the only noticeable thing that occurs is that the steering wheel buttons dont work after the error is on, but... Once it goes away randomly ether in couple seconds or a min time span, the steering wheel buttons operate and everything is normal again..
Looked all over and couldnt get info smh... , looking for help please haha. Thank you for reading and have an great day!
      04-03-2017, 07:08 AM   #2
jmordoj
jmordoj's Avatar
Chile
Drives: 2014 BMW 335i
I have the same problem, did you ever got it checked?
      04-05-2017, 03:07 PM   #3
f30GTR
f30GTR's Avatar
54
Drives: 2014 AW F30 335i M-Sport MT
It's your switch steering column. I had the same issue but it's not random it can be reproduced under certain angle of your steering wheel. Dealer fixed the issue by replacing this http://www.realoem.com/bmw/enUS/show...diagId=61_2982
The dealer told me it had shorted out. I think it's just a faulty part.
      04-08-2018, 01:19 PM   #4
kwstandard
AutoPilot
97
Drives: 19 X1,18 M550i,15 X5,14 328d
2011 Mercedes GL550  [0.00]
2019 BMW X128i  [0.00]
2015 X5 XDrive35i  [0.00]
2018 M550i  [0.00]
2014 328d  [0.00]
Same issue here... Do you have a part number? The link goes to the Main Page for F30 - not a particular part.
      04-23-2018, 03:18 PM   #5
kdnypunchr
Drives: 2014 f30 n55
Good to know I'm not alone. Same issue here. Taking it to the dealer.
The annoying thing is that the message disappears before I can read any codes, still trying to catch the code but it's still very random.
      04-30-2018, 11:27 AM   #6
Lance51391
Lance51391's Avatar
Drives: Glacier metallic f30 335
Anyone figure out the part number for this yet?
      11-18-2018, 10:18 AM   #7
BimmerMat135
Drives: E82M/S213 E450 A/T
I have the same issue as well. The first time it happen i try the cruise control 30 seconds after and it was working fine.:
      02-16-2019, 04:01 PM   #8
mclark2112
mclark2112's Avatar
109
Drives: 2018 BMW X3 M40i
I just started seeing this after swapping steering wheels. It pops up, goes away, and everything works as normal.
I'll put the other wheel back on to see if it is related to something in the wheel.
EDIT: Found this thread https://f80.bimmerpost.com/forums/sh....php?t=1383004
GOing to swap the innards of my old wheel, and see if that fixes it. Just trying to install paddles
      02-20-2019, 04:16 PM   #9
mclark2112
mclark2112's Avatar
109
Something with the controls on the new steering wheel was causing this, swapped my old controls in and the error is gone.
      03-28-2021, 10:08 PM   #10
MarcusF30ish
Drives: 2014 328i xDrive
I'm having the same issue on my 2014 328i. Whenever I turn the wheel, the code goes away and the buttons on the wheel work again. The malfunction happens randomly and usually at slower speeds.
      03-29-2021, 08:43 AM   #11
BMWILUVU
Drives: 340ix
I had cruise control intermittent failures and button lights go off. Replaced the wiring harness and everything is fine. This seems to have been a problem since the e-series.
      01-14-2022, 01:17 AM   #12
shady_rulls
Drives: White F36
Hi,
you replaced the wire harness of the buttons? Or what wire harness?
Thx
      01-14-2022, 12:18 PM   #13
BMWILUVU
Drives: 340ix
Originally Posted by shady_rulls View Post
Hi,
Thx
Wire harness within the steering wheel which connects the various components such as the left right sets of buttons aside of the horn.
      09-13-2022, 06:22 PM   #14
JayFrm100
Drives: 2016 bmw 340i
@mcclark did you swap your old control unit in or just the old harness?
f30post
