2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions BMW F10 Pre-LCI steering wheel retrofit with M Sport LCI
      09-21-2016, 09:29 AM   #1
MPertz
Drives: F10 520d
Hello Friends
I decided to "upgrade" my sport steering wheel (has shift paddles)(2010) with the LCI M Sport steering wheel (has shift paddles).
Process went pretty fast, but I'm finding myself with an issue now:
Situation 1: Start engine, hit the DRIVE (automatic) and instead of showing me D it shows M. I'm able to change the gears only from the paddles. Gear lever would not do anything not even in M/S mode. Also, while changing gears from the paddle is reversed: + is - and - is +.
Situation 2: after driving few minutes and not changing the gears, it moves automatically in D, and the paddles don't work anymore. Gear lever works as usual in D, M/S.
In the attached images you can see that the original SW has 6 wires in the connector, while the LCI SW has only 5.
On the original SW, commands connector (from left to right) cables are the following:
1. Mauve - I suppose it's the horne
2&3 White & Maroon are paddle shifters
4,5,6 - Thick maroon, red, blue - rest of the commands.
On the LCI SW, I couldn't check yet the harnesses.
There are no other "symptoms", nor errors.
      09-22-2016, 12:49 PM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
The resistance pull up values on the LCI paddles are wrong for your pre-LCI vehicle.
I go into some detail on this in my thread:
http://f10.5post.com/forums/showthread.php?t=1274977
      09-23-2016, 07:18 AM   #3
MPertz
Drives: F10 520d
Hello Stück,
I've read your posts. So few questions:
1. Should I assume that I have an F30 wheel and not F10 LCI?
2. What Control Module did you buy? Eventually PN
3. do I have to replace the resistors also?
..this given the fact that my wheel is acting similar like yours.
Thanks
      09-23-2016, 07:51 AM   #4
Stück
Stück's Avatar
The F30 wheel won't bolt to the F10, the splines are different sizes.
I only had F30 paddles, I swapped the SMD resistors for the correct values.
You can get the correct values from your pre-LCI paddles you still have.
Control module PN was to get the heated wheel working, nothing else.
      09-26-2016, 05:32 AM   #5
MPertz
Drives: F10 520d
So you're saying that if I'm replacing the resistors, problem should be solved. All of the other commands are working perfect.
      11-12-2017, 10:32 PM   #6
pika1460
pika1460's Avatar
17
Drives: e92
I did that to an older Opel i had (saturn in the US). Just measure the resistor values in your current steering wheel and duplicate them in your new one. Also the + and - might be reversed. I experienced a similar situation on an e92 setup.
      09-18-2018, 07:00 AM   #7
marmit2017
marmit2017's Avatar
Drives: 11 535i 13 328i xDrive
Quick question. The lower trim of the sport steering wheel that goes below the airbag, is it held in with screws or just clips? Wanting to replace mine as it is getting worn and didn't want to break anything
      09-20-2018, 05:14 PM   #8
sweettalker
Drives: Vrooom
What if i take my pre lci paddle shifters and just move it over to lci steering wheel,will that work?
Akso is there any paddle shifters thats bolt on without needing the resister work?
      02-25-2020, 12:05 AM   #9
marmit2017
marmit2017's Avatar
Originally Posted by MPertz View Post
Hello Stück,
Thanks
What did you end up doing? Im running into the same issue
      04-03-2024, 02:18 PM   #10
crm123
Drives: F01 pre LCI
Hello. I have a problem. I installed the steering wheel with paddles from the F10 LCI.
My car is F01 pre LCI and the paddles don't work.
What resistors do I need to use for the paddles to work?
Thx
      04-04-2024, 12:27 PM   #11
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
Thx
Just follow the link in the second reply to this thread.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-05-2024, 04:26 AM   #12
crm123
Drives: F01 pre LCI
Hi. there is no answer to my problem there. they have Paddles f30 and an f10 LCI car.
I have a pre LCI car and f10 LCI paddles. it's not the same thing that's the problem ☹️☹️☹️
      04-06-2024, 01:56 PM   #13
Unspec
Unspec's Avatar
1312
Ah, you have a 7 series. Pre-LCI 7 series don't support paddle shifters. Straight up.
2015 BMW 535xi
