2010 2011 BMW 5 Series Forum F10 BBS CH R 2 on 2011 F11? Offset / J question |
10-02-2016, 02:21 PM | #1 |
Rep 227
Guys,
I'm sure this question came up on here many times, so go easy on me I am trying to figure out if i will be able to fit 20/ 9j et25 and 20/ 10.5j et35 on my 2011 f11 m sport. BBS a doesn't make Ch r 2 in 10j and I am worried 10.5j with et35 will rub somewhere. I also don't want the rim to protrude out of the arch, I want it flush. I've seen people running 10.5j on f10. Is it exactly the same suspension for f11? I will appreciate you view on this. Btw. My 530d sits on h&r sport spring in front. Rear is standard at the moment but I will be installing drop links from the same set. Many thanks, Art |
10-02-2016, 06:34 PM | #2 |
Rep 29,202
Here's a f11 with BBS CH-R wheels 20x9 ET29 front and 20x10.5 ET35 rear, and I think it's lowered on Hartge springs.
10-03-2016, 02:40 AM | #3 |
Rep 227
Thanks Mr R! I am guessing the difference et25/et29 wont be a deal breaker then?
I have to say though the rear on these pics looks like it sticks out a bit - or is it only my eyes? Ideally i wanted to run a square look pss so I am not convinced, based on these, if I wont rub? |
10-03-2016, 03:38 AM | #4 | |
Rep 29,202
So if you don't like that, a square setup with 20x9 ET25 might be better.
10-03-2016, 04:24 AM | #5 |
Rep 227
cool. since there is no 10j in chr2, I am toying with a 9.5j and a small spacer.
what about the front? 8.5j with a 5-7mm spacer or 9j? I have 351 on now and from what i can see I have around 10mm on the outer side availabe. 9j on et25 , pushes me out 14.4mm. I can see you running 9j fronts, is the rim sticking out a little as well? btw. I appreciate your help buddy Last edited by Oompah; 10-03-2016 at 04:35 AM.. |
10-03-2016, 05:20 AM | #6 | |
Rep 29,202
And if you look at the F11 above with ET29 in the front, 4mm more aggressive fitment wouldn't hurt.
03-31-2017, 07:15 PM | #9 |
Rep 14,522
Nice! that came out pretty damn SWEET!
04-01-2017, 03:50 AM | #10 |
Rep 227
thanks gents.
I am currently sitting on 255 35 20 9j 285 30 20 10.5j - but even though i am lowered a bit, there is still some room to squeeze 35s, which i prefer the look of |
