| 06-11-2017, 04:48 PM | #1 |
![]() ![]() 65
Rep 336
F10 rear rattle
Hi
Got a real annoying rattle from rear of car. It's definately coming from inside, think rear vent. Any ideas how to fix it. Btw rear seats are not folding. |
| 06-12-2017, 04:12 PM | #2 | |
![]() 61
Rep 293
| 06-13-2017, 06:14 PM | #3 | |
![]() ![]() 65
Rep 336
I removed the third brake light and out some foam tape around the edges. Made a small difference but there's still a obvious rattle. Any other suggestions? |
| 06-14-2017, 01:30 AM | #4 |
Rep 1,597
Have you checked the locking wheel nut key in the compartment in the lid of the trunk? Mine occasionally works loose and causes a rattle...
| 06-14-2017, 02:41 AM | #5 |
![]() ![]() 65
Rep 336
| 06-14-2017, 09:16 AM | #6 | |
![]() 67
Rep 235
My F10 also has a rattle from the 3rd brake light area - how did you remove it to apply the tape? I had a go at trying to remove the section of headlining by hand and I can see it's clipped in, don't want to apply too much force in case I permanently damage it.... |
| 06-14-2017, 12:37 PM | #8 |
![]() 67
Rep 235
I put a couple of small pieces on the back part of the cupholder assembly on the outside edges where it slides against the front part. There is a also removable storage box behind the armrest which provides access to the boot. This has some tape on the opening flap of the storage box. Only by stopping that lot rattle did i discover the rattle in the roof.... Thanks for the tip, i managed to get it off and have applied more tape inside that. Will test drive it tomorrow.
| 06-16-2017, 08:02 PM | #11 | |
![]() ![]() 65
Rep 336
| 06-17-2017, 08:14 AM | #13 |
![]() ![]() 65
Rep 336
| 06-17-2017, 10:20 AM | #14 |
Rep 1,597
| 06-17-2017, 11:16 AM | #15 |
![]() ![]() 65
Rep 336
Finished about two months ago.
Also realised the rattling is more obvious when it's cold / or when the ac has been on for a while. Last edited by creativ101; 06-17-2017 at 12:21 PM.. |
| 06-23-2017, 07:46 PM | #16 |
![]() ![]() 65
Rep 336
Think I may have worked out where that noise is coming from. The rear centre headrest. But it's intermittent. If I move it I can replicate the noise. Question is, what can I use to stop the noise? A bit of wd40 maybe?
| Bookmarks |
