2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum cigarette lighter fuse replacement
      08-01-2017, 01:55 PM   #1
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
my cigarette fuse has been blown for a couple of years now lol and i never got around to replacing it. so i'll be driving to MPACT East 2017 from Ohio to PA so i want to be able to charge my phone which i will be using the GPS to get there. i've heard it's under the glove box and i found this schematic and want to confirm if fuse #54 or #65 is the one where the cup holders is? or is it in the trunk since they list multiple fuses for the cigarette lighter? also, what size amps is it and if it's the normal size fuse or the smaller one's? any tips or tricks? if anyone has done there's please chime in i would really appreciate it! thanks!
      08-01-2017, 03:23 PM   #2
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
224
Drives: 2011 550i m sport
Its fuse 54, 20amp.
      08-01-2017, 08:06 PM   #3
lsturbointeg
Originally Posted by Teddylongtooth View Post
Its fuse 54, 20amp.
Thanks Teddy! Do you know if its the small or larger fuses?
      08-01-2017, 08:07 PM   #4
Drives: 2014 535i M Sport
Can't you just use the USB port in the console?
      08-01-2017, 08:10 PM   #5
lsturbointeg
That's what ive been using for the past couple years however it doesn't charge as fast
      08-01-2017, 08:14 PM   #6
Royer.....
      08-01-2017, 08:16 PM   #7
lsturbointeg
Royer.....
What's that bro?
      08-01-2017, 08:32 PM   #8
Teddylongtooth
ZEROdoubleZERO
224
The center console usb port is not for phone charging its for data only.
      08-01-2017, 08:34 PM   #9
Teddylongtooth
ZEROdoubleZERO
224
Its the big one.
      08-01-2017, 08:35 PM   #10
lsturbointeg
Im not sure on the size, why dont you just pull it out and match it up?
I'll probably pick up a fuse kit with different sizes
      08-01-2017, 08:41 PM   #11
Teddylongtooth
ZEROdoubleZERO
224
Its the bigger fuse.
      08-01-2017, 08:44 PM   #12
lsturbointeg
Ok cool!
      08-01-2017, 08:46 PM   #13
Teddylongtooth
ZEROdoubleZERO
224
Ok cool!
Its a PITA to get out, you might want to use needle nose pliers to get it in and out easier.
      08-01-2017, 09:20 PM   #14
TZ
Drives: 2011 535i xDrive
You may have spare fuse in the fuse box. I replaced it while ago. Can't remember.
2011 535i xDrive Black/Black
Service Manual: www.newtis.info
Part: http://www.realoem.com
      08-01-2017, 09:45 PM   #15
lsturbointeg
I'll have to check but good to know
      08-01-2017, 11:17 PM   #16
What's that bro?
That's how the Mexican airlines say "roger". Picked that up at work.
That USB charges my phone.
      08-02-2017, 12:11 AM   #17
Teddylongtooth
ZEROdoubleZERO
224
Im simply pointing out its a data port not ment for charging, read your manual.
      08-02-2017, 05:41 AM   #18
ALPWhite
Drives: 2013 Alpine White 535iX MSport
It's in the glovebox, had to replace mine about a year ago. Use needle nose pliers to get it out, much quicker.
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      08-02-2017, 08:09 PM   #19
lsturbointeg
AWESOME! love pictures and this makes it so much easier for me to look for
ALPWhite122.50
      08-16-2017, 06:07 PM   #20
lsturbointeg
just an update on this! so it is a 20 amp fuse and i had no idea there was a cover covering the fuses in the glove box so i'm looking around going WTF? where is the fuse panel lol as i'm looking at the picture posted above! anyways i figured it out and boy what a pain it was getting the fuse out! even the damn fuse remover that came with the fuse kit didn't work. the fuses are soooo tight together you couldn't get them to separate for the tool to grab. even when i used a needle nose. i ended up just reaching in there and pulling with my finger nails. anyway, just thought i'd let everyone know how it went
      08-16-2017, 09:17 PM   #21
TZ
You need this.
      08-16-2017, 09:57 PM   #22
lsturbointeg
You need this.
i used something similar to that! are the tips pretty thin/small? you can see how there's literally no space between the fuses
Copyright ©2000 - 2020, vBulletin Solutions Inc.
