2010 2011 BMW 5 Series Forum F10 6WA Cluster Retrofit Help |
02-15-2018, 07:53 AM | #1 |
Rep 78
Hey all,
So I'm hoping to get some assistance with a 6WA cluster retrofit for my 535i. I was able to buy an already cleared cluster on ebay that shows 00 miles and has no VIN assigned. I wanted to confirm if the attached PDF shows the correct instructions for performing the retrofit? I am guessing that I will be starting with section 5 (highlighted) since the cluster has already been cleared. If someone has done this, is there anything you see that might be missing? Also, the person I bought the cluster from mentioned that I "might" need to update / change the build date of my vehicle. Can someone provide me with some help on how to verify if that will be required? I did not see that in the attached tutorial so trying to make sure I don't end up with any errors. Also, is there (and what would be the steps) to create a "backup" of the old setup in case something goes wrong or does not code correctly so I can still have a functional car? Thanks for all the help. |
