2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Boost Lag after Wagner Intercooler install
      05-14-2018, 12:16 PM   #1
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
F10 N55 Pwg , just installed the Wagner intercooler and now noticing a lot of Lag and hesitation/surging at WOT. Car has No Boost Leaks (pressure tested fine). Thinking of re installing stock FMIC and calling it a day....Anybody else have these issues after installing the Wagner intercooler (which has 100% more air flow) which seems to be too much. You can tell by looking at it that HUGE !!!!!!!
Link below to pics
https://f10.5post.com/forums/showthread.php?t=1314941
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      05-14-2018, 12:53 PM   #2
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
Do you wanna sell it?
      05-14-2018, 12:54 PM   #3
ssgm1x
ssgm1x's Avatar
Sure
      05-14-2018, 03:23 PM   #4
paul223
paul223's Avatar
Drives: F10
you should not experience any issue. Car should feel stronger with lower IAT, you should double check installation.
      05-14-2018, 03:29 PM   #5
AZ-MCRacer
AZ-MCRacer's Avatar
306
Drives: 2022 G82 M4, 2013 F10 N55
I've been running the Wagner for almost a year and half and never felt like I had more lag using it. This was both stock turbo and with upgraded PS2 Turbo.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD!
1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped
      05-14-2018, 03:30 PM   #6
ssgm1x
ssgm1x's Avatar
It's just 2 hoses. Not much else to check on FMIC install. Did a pressure too. No leaks... the fmic is 100% larger in volume and physical appearance. So I'm assuming it is just too big. Regardless I am removing it. It did not gain me any performance at all. Just more consistent IAT. Car felt MUCH faster and Peppy before the fmic. Anybody interested in purchasing a F10 N55 Wagner intercooler please email me here. Paid $900 selling $675 shipped anywhere in USA
      05-14-2018, 03:35 PM   #7
ssgm1x
ssgm1x's Avatar
I installed it myself. Was easy to install. Just 2 Hose's. Hardest part was fitting it in place. Also did a leak test afterward and no leaks.
So What am I missing here ? Defective FMIC ? Temps do go down during pulls so I know it's working fine. I just think it's too big in volume. The Lag is Harsh too. It's extremely noticeable. Have u seen the F10 N55 Wagner fmic. It's HUGE!!!!! No other bmw has an aftermarket FMIC this big.
      05-14-2018, 03:37 PM   #8
ssgm1x
ssgm1x's Avatar
Here's some pics of the Wagner fmic vs stock fmic
      05-14-2018, 07:17 PM   #9
ssgm1x
ssgm1x's Avatar
Just removed Belly pan cover. Checked intercooler connections. One side looks good, other side looks like it's coming off but not sure. I guess I have to Smoke Test / Boost Pressure year it again. Then if this is the cause, will remove it and reinstall it. What do u guys think by looking at this connection. I will show Left side connection (looks good) and I will show right side connection ( looks like coming off ). What do u think from these pics?????
      05-14-2018, 07:19 PM   #10
ssgm1x
ssgm1x's Avatar
And here's a pic of other side of intercooler where the connection looks solid!!!
      05-15-2018, 12:52 AM   #11
AZ-MCRacer
AZ-MCRacer's Avatar
306
Can you post logs? Guessing is pretty pointless.
      05-15-2018, 01:30 AM   #12
ssgm1x
ssgm1x's Avatar
I don't see anything alarming in this log that pertains to boost leak. This is what confuses me. 2 Logs below. Tell me if u see Boost Leak......
https://datazap.me/u/ssgm1x/mhd-2-1?...-5&zoom=44-113
https://datazap.me/u/ssgm1x/mhd-2-1?log=2&data=4-22
      05-15-2018, 08:36 AM   #13
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
I just looked at the first....
You appear to be under on both boost vs boost targets and load vs load targets. Also, A/F seems rich at the low end. 10.xx is pig rich. Did your have those traits before the FMIC install?
      05-15-2018, 08:41 AM   #14
ssgm1x
ssgm1x's Avatar
https://datazap.me/u/ssgm1x/mhd-stag...2-22&solo=4-12
Here is a Prior Log on a Stage 2 Map prior to fmic install and no boost leak suspected. Afr is much leaner down low. Not sure if it's due to change of Map.
      05-15-2018, 03:25 PM   #15
ssgm1x
ssgm1x's Avatar
https://datazap.me/u/ssgm1x/mhd-stag...&solo=4-12
Got a boost leak test done. No leaks at all.... go figure. Regardless we put back the original FMIC. Will troubleshoot Plugs and Coils now. Putting back my original Plugs and Coils with stock gap.
      05-16-2018, 07:10 PM   #16
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
So I see "ECU remap" in your sig line, who exactly did your tooon?
I noticed no drivability difference what so ever when installing my Wagner intercooler, and to say its oversized is a GD joke. It keeps IAT's from rising under load and allows for multiple pulls without heat soaking as bad.
You should see the size of the intercoolers we install on 6, 7, 800+ hp N54 cars to keep them cool.
      05-16-2018, 07:23 PM   #17
ssgm1x
ssgm1x's Avatar
R we talking about my tune or Fmic ??
I currently Have BM3 Stage 2 . Had MHD and MP prior. No issues at all any of the tunes aside from Slight PWG overboost.
Now, Talking about Wagner Fmic....
I had the fmic installed along with plugs and coils and a new battery and Remus exhaust all at the same time. Since then car has tremendous lag. Removed Remus exhaust still have lag ( ton of drone so removed )Just did a boost leak test and have no leaks... so I am still troubleshooting the lag issue. Not sure if it was the Wagner fmic or not so will be putting back stock fmic until I can figure this out. I just don't know what happened......
Hope this answers any questions u had.
      05-16-2018, 07:34 PM   #18
ssgm1x
ssgm1x's Avatar
What do u think would cause of this lag ? Also have a slightly rough idle now.
Also gapped the new plugs .025.
No Cel codes.....
At Low rpm runs a little rough. High rpm runs fine.
Next troubleshooting step I'm thinking gonna put new Oem coils and stock plugs back in with stock gap. Clean Map sensor and replace boost solenoid. And hope this fixes it.
      05-17-2018, 08:17 AM   #19
n3985
Drives: a car
Did you register your new battery?
      05-17-2018, 09:13 AM   #20
ssgm1x
ssgm1x's Avatar
Yes. Used the Carly OBD/App to Register and Code in new battery. Very easy to do and the new battery is so much better. Can now flash car without a battery tender.
I did notice a lot of carbon dust or particles inside the spark plug chamber when doing plugs. Not sure if u can zoom in and see that in the pics.
      05-17-2018, 11:38 AM   #21
ssgm1x
ssgm1x's Avatar
Let's try Oem Plugs and Coils now with stock gap. Gonna clean out the carbon dust in spark plug channel as well will report back on my results.
      05-18-2018, 07:58 AM   #22
paul223
paul223's Avatar
Drives: F10
I have 2013 535i, OEM coils look like Delphi brand, has metal surrounding.
