2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Got beef? 315/30 r888r
      06-08-2018, 08:13 PM   #1
M335
M335's Avatar
47
Drives: E90 n55 IG@FrozenF10
Hello guys, I’m planning to fit 305/35/20 or even 315/30/20 r888 on the back of my 550i for a better traction & wonder if anyone has done that before on regular 5 series
Thinking of 20x11 with et40
Here’s how it sits right now on original forged M5 343 M (20x10 et36) wheels stock suspension & 285 PSS, perfect fitting no rubbing but luck of traction
Edit: just went and order 315/30/20 R888R Toyo’s
IG:@FrozenF10
      06-09-2018, 09:18 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
305/35-20 won't fit with ET40.
That tire is 7% taller than OEM rear 20" size (275/30-20).
295/35-20 (6% taller) will fit with 10" wide wheels and ET40, not sure about 11" though.
305/30-20 (3% taller) might be another choice.
      06-29-2018, 09:10 PM   #3
M335
M335's Avatar
47
How about 20x11 with et43
Anyone run this?
      06-29-2018, 11:40 PM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
this is my 20x11 et 40mm 295's and I don't think I can fit a 305 without issues?
M33546.50
mragarg63.50
BurrNinja427.50
      06-30-2018, 12:21 PM   #5
xxpanipuri
Drives: 550i
Originally Posted by M335 View Post
Hello guys, I’m planning to fit 305/35/20 r888 on the back of my 550i for a better traction & wonder if anyone has done that before on regular 5 series
Here’s how it sits right now on M5(20x10 et36) wheels stock suspension & 285 PSS, perfect fitting no rubbing but luck of traction
so here's what i did...if your wheels today with the 285 fits fine...then go check the specs on your new tires you wanna get and measure...tire rack has all the specs.
so for example, the 285 in hankook vs 295 in mich pss was vastly different in terms of width (as the pss seems to run a bit wider than most)...
      07-01-2018, 05:25 PM   #6
M335
M335's Avatar
47
Be honestly with 650+hp I really need toyo r888 315/30/20 on the back
      07-02-2018, 06:03 AM   #7
SLOW550i
SLOW550i's Avatar
Drives: 2011 550i
any new information????? these are the same tires I want to run for the hell of it... because all of the traction.. I'm gonna be running the H&R lowering springs wanting to see the best option to go with... I know it all matters in the offset of the wheel
      07-07-2018, 12:39 AM   #8
M335
M335's Avatar
47
Nope, looks like no one done 12" on the back period not even 11.5" with beefier tires
      07-24-2018, 11:40 PM   #9
M335
M335's Avatar
47
Got my r888r Toyo’s 315/30/20 (there’s maybe 2-3mil between shock tower & tire,its 13 1/8” wide side to side, offset must be on the spot) can’t wait to get my custom BC Forged wheels 20x9.5 & 20x11.5
[IMG][/IMG]
      07-25-2018, 03:13 PM   #10
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
I'm putting down 700+whp on a 305/30R20 Michelin P4S without issue. 1st spins a little, 2nd on up is 100% usable.
M33546.50
      07-25-2018, 08:56 PM   #11
M335
M335's Avatar
47
Yes, Michelin tends to run one size bigger vs all other brands therefore 305 Michelin would be wide as 315 other brand plus on 550i rear sub frame & suspension is different compared to M5 so offset is less aggressive.
      08-19-2018, 06:26 PM   #12
M335
M335's Avatar
47
Here’s small update on my new custom order BC-Forged 20x11.5” wheels with 315/30/20 Toyo R888R on the back & 285/30/20 PSS on front, no spacer’s, no rubbing
More pictures @FrozenF10
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
      08-21-2018, 11:14 AM   #13
BambuBoii
Drives: E93 M3
And how is the traction now??
      08-25-2018, 08:19 PM   #14
M335
M335's Avatar
47
Before on first & second gear I couldn’t get a traction at all-it just light up & no go on 285 pss... now, car will dead hook form a 2 gear roll,haven’t try from dig on first gear yet
