2010 2011 BMW 5 Series Forum F10 ISTA cant work on BMW if you have a retrofitted cluster? |
07-08-2018, 01:24 PM | #1 |
Rep 590
is that true? I can to run a diagnostics on my car but I have a retrofitted cluster and heard its not possible to if so :/
07-08-2018, 02:17 PM | #2 |
Rep 1,214
Obsolete information.
ISTA/D has always had no issue with it, ISTA/P would hang due to the incorrect equipment. BMW finally added an option to force ISTA/P to ignore the issue and just program everything else. This does assume you have up to date ISTA and not some old version. Last edited by Stück; 07-08-2018 at 02:26 PM.. |
07-10-2018, 08:38 PM | #3 |
Rep 966
Any chance you know which version? I have ISTA+ and ISTA/P relatively new, and I couldn't get past the "replace module" error as ISTA/P did not ignore it. I've love to know the version # since this feature got enabled.
I have a cluster and a RDC module that I need programmed to the car |
02-05-2021, 06:46 AM | #4 |
Rep 596
Drives: 2014 X5 35d, 2008 Lexus IS-F
I think I'm in the same boat if anyone can help me.
I've got ISTA+ 4.25 installed with all data but after I get the plan for programming, the execute program box is not available. I get no errors or anything, and installed it exactly how it's shown on the you tube video. I do get the "make sure maintain power" dialogue box, but I have my battery maintainer supplying 13.7v @70A+. I do have a retrofitted 6WB. Not sure why it's not letting me upgrade my ECUs. It's telling me there are 44 modules that require upgrading when ever I run the program and istep is from 2017. I'd post pictures but I'm currently away from home. Any help? |
02-05-2021, 10:24 AM | #5 | |
Rep 2,637
You have an ICOM device right?
2015 BMW 535xi
02-05-2021, 01:43 PM | #6 | ||
Rep 596
Guess I need to get me an icom then, and now I know who doesn't know what they are talking about 😒 Thank you |
02-05-2021, 10:49 PM | #7 | |
Rep 2,637
ENET = programming with ESYS
2015 BMW 535xi
XxBBVTMxX328.50 |
