2010 2011 BMW 5 Series Forum F10 Stock exhaust diameter 2015 535i. |
07-23-2018, 12:12 AM | #1 |
Rep 238
Drives: 2015 M3
Whats the stock exhaust diameter on a 2015 535i?
Cheers |
07-23-2018, 12:32 PM | #3 |
Rep 238
Drives: 2015 M3
07-25-2018, 01:52 AM | #4 |
Dream crusher
984
Rep 2,421
I do t think it's exactly 2.5
It's something like 2.36
IG: @bmwdoubles |
Unspec1311.50 poverty.f1078.00 |
03-16-2020, 12:26 AM | #6 |
Rep 2,595
Doubles is right, BMW doesn't use SAE. They use metric. It's 60mm OD for a lot of the exhaust clamps, which converts to 2.36 or so inches.
2015 BMW 535xi
03-16-2020, 07:30 AM | #7 | |
Rep 1,299
Do you think 2.5 inch would work with clamps or should I just get it welded? I can't seem to find that diameter x-pipe. Last edited by ziekxq; 03-16-2020 at 07:36 AM.. |
03-16-2020, 09:06 AM | #8 |
Rep 2,595
It's a 3mm difference. If you don't want to weld, you could ask the shop (or do it yourself) to make small slots on the end, one on each side of the pipe, so that it can bend a bit when you clamp it. Or just say fuck it and clamp it down REAL hard
2015 BMW 535xi
